I am receiving an ImportError from esptool. While the downloads page says 10.14 is still supported, I do notice the following possible relevant in the traceback:
_ctypes.cpython-38-darwin.so (which was built for Mac OS X 10.15)
Arduino IDE 1.8.19 and 2.0.0, all libraries and boards up to date
Mac OS Mojave 10.14
Python 3.6.5
The example below is trying to compile/verify with an empty sketch. My environment worked as of a month ago, but I did accept library and board definition updates. This behavior is the same in 1.8.19 and 2.0.0.
Thanks!
Traceback (most recent call last):
File "esptool/loader.py", line 48, in <module>
File "PyInstaller/loader/pyimod02_importers.py", line 493, in exec_module
File "serial/tools/list_ports.py", line 31, in <module>
File "serial/tools/list_ports_posix.py", line 33, in <module>
File "serial/tools/list_ports_osx.py", line 26, in <module>
File "ctypes/__init__.py", line 7, in <module>
ImportError: dlopen(/var/folders/8x/fqxqxbq96s1bs57318xzvpm00000gp/T/_MEID4ngyt/lib-dynload/_ctypes.cpython-38-darwin.so, 2): Symbol not found: _ffi_closure_alloc
Referenced from: /var/folders/8x/fqxqxbq96s1bs57318xzvpm00000gp/T/_MEID4ngyt/lib-dynload/_ctypes.cpython-38-darwin.so (which was built for Mac OS X 10.15)
Expected in: /usr/lib/libffi.dylib
in /var/folders/8x/fqxqxbq96s1bs57318xzvpm00000gp/T/_MEID4ngyt/lib-dynload/_ctypes.cpython-38-darwin.so
During handling of the above exception, another exception occurred:
File "esptool.py", line 31, in <module>
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "esptool/__init__.py", line 42, in <module>
File "esptool/cmds.py", line 14, in <module>
File "esptool/bin_image.py", line 14, in <module>
File "esptool/loader.py", line 53, in <module>
AttributeError: module 'sys' has no attribute 'VERSION'
[41626] Failed to execute script 'esptool' due to unhandled exception!
exit status 1
Compilation error: exit status 1
