Hola gente;
Acabo de terminar de disenar my projecto (estacion meteorologica) con un pluviometro y tres sensores de temperatura adaptados a una adafruit datalogging con SD card y RTC.
Todo va bien, excepto que no consigo imprimir los valores de temperatura en la sd card.
Este es el codigo completo
/*-----( Declare Libraries )-----*/
#include <SPI.h>
#include <SD.h> //Ensure that you downlaod these libraries and store them in your Arduino libraries folder
#include <Wire.h> //Remember no semi-colon after these commands
#include "RTClib.h"
#include <OneWire.h>
#include <DallasTemperature.h> //Get DallasTemperature Library here: http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
/*-----( Declare Constants and Pin Numbers )-----*/
const int REED = 9; //The reed switch outputs to digital pin 9
int val = 0; //Current value of reed switch
int old_val = 0; //Old value of reed switch
int REEDCOUNT = 0; //The intial count is zero
const int chipSelect = 10;
File logfile;
#define SYNC_INTERVAL 60000
#define ONE_WIRE_BUS_PIN 2
uint32_t syncTime = 0; // time of last sync()
/*-----( Declare objects )-----*/
RTC_Millis rtc; /////RTC_DS1307 RTC; // define the Real Time Clock object
OneWire oneWire(ONE_WIRE_BUS_PIN);// Setup a oneWire instance to communicate with any OneWire devices
DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
/*-----( Declare Variables )-----*/
DeviceAddress Probe01 = {
0x28, 0x5A, 0xB7, 0x00, 0x00, 0x00, 0x80, 0x6D };// Assign the addresses of your 1-Wire temp sensors.
DeviceAddress Probe02 = {
0x28, 0x5C, 0xB7, 0x00, 0x00, 0x00, 0x80, 0xDF };// See the tutorial on how to obtain these addresses:
DeviceAddress Probe03 = {
0x28, 0x12, 0x6D, 0x73, 0x06, 0x00, 0x00, 0x27 };// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
/////////////Program Set-up/////////////////////////////////////////////////////////////////////
void setup(void){ /****** SETUP: RUNS ONCE ******/
Serial.begin(9600);// start serial port to show results
pinMode (REED, INPUT_PULLUP); //Activate the internal pull-up resistor
/////////////Setting up the file on the SD Card///////////////////////////////
Serial.println("Initializing SD card...");
pinMode(10, OUTPUT); // make sure that the default chip select pin is set to output
if (!SD.begin(chipSelect)) { // see if the card is present and can be initialized:
Serial.println("Card failed, or not present");
Serial.println("card initialized."); // create a new file
char filename[] = "LOGGER00.CSV"; //The file names must be in the 8.3 format
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
Serial.println("could not create file");
Serial.print("Logging to: ");
Serial.println(filename);
rtc.begin(DateTime(F(__DATE__), F(__TIME__)));
/////rtc.adjust(DateTime(2015, 7, 7, 12, 40, 0));
Serial.print("Initializing temp. sensors.");
Serial.println(" Reading 3 probes:");
logfile.print("Temperatures and ");
sensors.begin();// Initialize the Temperature measurement library
sensors.setResolution(Probe01, 10);// set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
sensors.setResolution(Probe02, 10);
sensors.setResolution(Probe03, 10);
Serial.println("Rainfall, Reading/count, Time, Date:");
logfile.println("Rainfall, Reading/count Time Date");
}//--(end setup )---
///////////////////The Program Loop//////////////////////////////////////////////////////////////////////
void loop(){ //****** LOOP: RUNS CONSTANTLY ******/
DateTime now = rtc.now(); /////DateTime now; // and record date/time of change
val = digitalRead(REED);
if ((val == LOW) && (old_val == HIGH))//Low means that the Reed switch is open (which happens when the magnet passess).
delay(10); // Delay put in to deal with any "bouncing" in the switch.
char buf1[50];
Serial.print("Precipitation");
Serial.print(" = ");
REEDCOUNT = REEDCOUNT + 10;
old_val = val;
Serial.print(REEDCOUNT);
Serial.print(" ml of rain ");
sprintf(buf1, "at %02d:%02d:%02d of %02d/%02d/%02d", now.hour(), now.minute(), now.second(), now.day(), now.month(), now.year());
Serial.println(buf1);
logfile.print("Precipitation");
logfile.print(" = ");
logfile.print("10");
logfile.print("ml at ");
logfile.println(buf1);
else {
old_val = val; //If the status hasn't changed then do nothing
if ((millis() - syncTime) < SYNC_INTERVAL) return;
logfile.flush();
syncTime = millis();
Serial.print("Number of Devices found on bus = ");
Serial.println(sensors.getDeviceCount());
Serial.print("Getting temperatures... ");
//char buf1[50];
sensors.requestTemperatures(); // Command all devices on bus to read temperature
Serial.print("Probe 01 temperature is: ");
printTemperature(Probe01);
Serial.print("Probe 02 temperature is: ");
printTemperature(Probe02);
Serial.print("Probe 03 temperature is: ");
printTemperature(Probe03);
// Serial.println(sensors.getDeviceCount());
//logfile.println("Temperature Probe 01 = ");
//logfile.println("Temperature Probe 02 = ");
//logfile.println("Temperature Probe 03 = ");
//logfile.println(buf1);
//sprintf(buf1, "at %02d:%02d:%02d of %02d/%02d/%02d", now.hour(), now.minute(), now.second(), now.day(), now.month(), now.year());
//Serial.println(buf1);
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00)
Serial.print("Error getting temperature ");
Serial.print("C: ");
Serial.print(tempC);
Serial.print(" F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
End printTemperature
He intentado cambiar los codigos, las localizaciones pero cuando aplico esta parte del codigo simplemente la sd card no me crea ningun file
Sabe alguien como puedo obtener las lecturas de precipitacion y temperaturas en la sd card? muchas gracias
