I'm building a system to estimate the concentration of microplastic in a tank full of sea water. The concentration of plastic will increase over time, as the water is filtered and return plastic free to the sea. When a concentration is reached, the plastic will be drained from the tank.
I am still in the comceptual phase, before making a new sensor for that, I'd like to know if there are products available to use or to at least help validate some hypothesis.
There are a few parameters I am considering to estimate the concentration of plastic in salt water: thrust, capacitancy and voltage drop. Please few free to sugegst any other as well as what I can use to do so.
You need to read whatever scholarly articles there are about detection of microplastic.
Try the internet thingy called Google and ask it about "microplastic detection in sea water"
What concentrations are we talking? Capacitance won't work in a conducting fluid with a very
large unstable dielectric constant!
As for voltage drop and thrust can you explain what you are thinking? Conductivity of sea water is totally
dominated by ion concentration, chelating agents and temperature I suspect.
Thinking about it C13 NMR would be a good way to detect non-CO2, non-carbonate
organic molecules, but I've no idea how sensitive it would be with a dilute sample, nor how
expensive!
Let me ask a stupid question. How do you know there is ANY plastic in the sea water? How you answer that question will also tell you how to determine the concentration.
We got good results measuring the electric resistance of the solution. Some more investigations still has to be done, but an ohm-meter is all we need so far!
zuanazzi:
Thank you all for the help =)
So a change in salinity tells you there is more plastic in the water?
Well for high concentrations you get steric hinderence effects, but you have to calibrate for baseline salinity
which means comparing to filtered water I think.
Wow - there is a team at my school that has used my FTIR instrument this semester to detect plastic content in pond water. I can pass your contact information to the PI if you'd like.
