Ethercard + Arduino posting data is blank in db
hi,
I'm using ENC28J60 with Arduino and using Ethercard library. When i url parse data from browser the data gets to the mysql db. But from Arduino it is post blank. below is my sketch and please help me to resolve this.
#include <EtherCard.h>
// your variable
String KEY = "A123DS";
String SID = "PS1"
// ethernet interface mac address, must be unique on the LAN
byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
const char website[] PROGMEM = "192.168.1.106";
byte Ethernet::buffer[700];
uint32_t timer;
Stash stash;
void setup () {
  Serial.begin(57600);
  Serial.println("\n[webClient]");
  if (ether.begin(sizeof Ethernet::buffer, mymac, 4) == 0)
    Serial.println( "Failed to access Ethernet controller");
  if (!ether.dhcpSetup())
    Serial.println("DHCP failed");
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
#if 0
  if (!ether.dnsLookup(website))
    Serial.println("DNS failed");
#else
  ether.parseIp(ether.hisip, "192.168.1.106");
#endif
  ether.printIp("SRV: ", ether.hisip);
void loop () {
  ether.packetLoop(ether.packetReceive());
  if (millis() > timer) {
    timer = millis() + 5000;
    byte sd = stash.create();
    stash.print("apikey=");
    stash.print(KEY);
    stash.print("station_id=");
    stash.print(SID);
    stash.save();
    Stash::prepare(PSTR("POST http://192.168.1.106/saveContactinfo.php?sd HTTP/1.0" "\r\n"
                "Host: 192.168.1.106 \r\n"
                "Content-Length: $D" "\r\n"
                "Content-Type: application/x-www-form-urlencoded \r\n"
                "\r\n"
                "$H"),
    stash.size(), sd);// website, PSTR(PATH), website,
    // send the packet - this also releases all stash buffers once done
    ether.tcpSend();
when i try this it send the data so maybe problem with stash or something when sending as stash
 Stash::prepare(PSTR("POST http://192.168.1.106/saveContactinfo.php?apikey=A123DS&station_id=PS1 HTTP/1.0" "\r\n"
                "\r\n"
                "$H"),
    ether.tcpSend();
So someone please tell me what i am doing wrong. I need an urgent help from you guys
Thanks is advance
  • have you tried to ensure reachability form your arduino to your network? are you sure that works?
  • what web server do you use? are you sure it's reachable outside the hosting machine?
  • what do you see in the logs of your web server?
as a side note, don't think it matters but
  • you have an extra space at the end of
    "Host: 192.168.1.106 \r\n" before the \r\n --> get rid of it
  • usually the size is the last element before the empty line, so I would move "Content-Type: application/x-www-form-urlencoded \r\n"before "Content-Length: $D" "\r\n"
I have done as mentioned. But still same issue. Blank data.
The connection between local server and device is working perfectly only thing is the data is empty.
192.168.1.107 - - [11/Jun/2017:22:15:07 +0500] "POST http://192.168.1.106/saveContactinfo.php?sd HTTP/1.0" 200 202 "-" "-"
I thinks still its a stash issue..anyway hoping for a solution
hold on - why do you have anything after your php in the URL?
    Stash::prepare(PSTR("POST http://192.168.1.106/saveContactinfo.php[color=red]?sd[/color] HTTP/1.0" "\r\n"
                "\r\n"
                "[color=green]$H[/color]"),
    stash.size(), [color=green]sd[/color]);// website, PSTR(PATH), website,
get rid of the ?sd
a POST method is not like a GET, you send the data outside the URL, in your HTTP request header which is what the $H and your sd variable will do
try with this:
void loop () {
  if (millis() > timer) { // THAT'S NOT THE RIGHT WAY TO DO THIS, should be millis()-timer >= 5000
    timer = millis() + 5000; // and here timer += 5000;
    stash.print(KEY);
    stash.print(SID);
    stash.save();
    Stash::prepare(PSTR("POST http://192.168.1.106/saveContactinfo.php HTTP/1.0" "\r\n"
                "\r\n"
                "$H"),
    ether.tcpSend();
--> but if your PHP expects things in the URL, that won't work. what you need then is a GET
I tried that too. Still same issue.
show your PHP...
are you expecting an URL formed like this:
--> if so you are expecting a GET request, not a POST probably
My php code will GET the values fed to URL. Exactly i was expecting something as J-M-L mentioned. when the stash sd value send from arduino i thought it would be as url formated. So what else i have to do to fix this. If you guide me i can try.
I already tried
``ether.browseUrl(PSTR("/post.php?"),buffer_data, website, my_callback);
this method and i am struggling to put double variables into the buffer_data. I am working on these two methods. but each is stuck in the middle. :frowning:
The http request you build is a POST, a GET does not look like this...
see this example
