Ethercard lib. and webclient example with big sites
Hi all,
I've the ENC28J60 board up and running and I'm planning to use the webclient example to retrieve the weather forecast on regular basis using the following URL: http://gps.buienradar.nl/getrr.php?lat=52&lon=4
// Demo using DHCP and DNS to perform a web client request.
// 2011-06-08 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[700];
static uint32_t timer;
char website[] PROGMEM = "gps.buienradar.nl";
// called when the client request is complete
static void my_callback (byte status, word off, word len) {
  Serial.println(">>>");
  Ethernet::buffer[off+300] = 0;
  Serial.print((const char*) Ethernet::buffer + off);
  Serial.println("...");
void setup () {
  Serial.begin(57600);
  Serial.println("\n[webClient]");
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
  if (!ether.dhcpSetup())
    Serial.println("DHCP failed");
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
  if (!ether.dnsLookup(website))
    Serial.println("DNS failed");
  ether.printIp("SRV: ", ether.hisip);
void loop () {
  ether.packetLoop(ether.packetReceive());
  if (millis() > timer) {
    timer = millis() + 5000;
    Serial.print("<<< REQ ");
    ether.browseUrl(PSTR("/getrr.php?lat=52&lon=4"), NULL, website, my_callback);
Unfortunately it seems that the website returns more data than my buffer can handle. The response is truncated somewhere in the middle as a result.
Is it possible to receive the contents "line by line"? I don't have to store the contents, I'm just interested in some datafields on each line....
  Ethernet::buffer[off+300] = 0;   ////////// Perhaps dropping a NULL terminator at offset+300 is the problem.  Try offset+length.
Get the latest version of Ethercard from GitHub
, there is a new function
persistTcpConnection(bool persist)
Set it to true, and your callback will be called for each data packet that is recieved in response to you browseUrl call
