Ethercard UDPlistener incoming data
I have a nano with a enc28j60 to which i've a working udpListener sketch as per the included library.
What i'm trying to achieve is to send a UDP of wither a "H" or "L" which for testing purposes turns an LED on and off, whilst also printing to the serial port.
Below is the included function i've modified from the ethercard library
void udpSerialPrint(uint16_t dest_port, uint8_t src_ip[IP_LEN], uint16_t src_port, const char *data, uint16_t len){
  IPAddress src(src_ip[0],src_ip[1],src_ip[2],src_ip[3]);
  Serial.print("dest_port: ");
  Serial.println(dest_port);
  Serial.print("src_port: ");
  Serial.println(src_port);
  ether.printIp(src_ip);
  Serial.println("data: ");
  Serial.println(data);
  //my added code
  if (data == "H"){
    digitalWrite(ledPin, HIGH);
    Serial.print("LED ON");
   if (data == "L"){
    digitalWrite(ledPin, LOW);
    Serial.print("LED OFF");
With the serial terminal open I can see that the nano is receiving the UDP character, but isn't acting upon it.
Form my rather limited programming knowledge I suspect its something to do with it incorrectly reading the data out of the buffer. The data is declared as a const char and given the variable *data as per the included example, however when it is printed to the serial terminal
the above works and prints the character to the terminal but the below doesn't print or turn the led pin high or low
if (data == "L"){
Any help would be greatly appreciated
if (data == 'L'){
You want to compare the received char to a character literal, not a string literal, because the string literal has an included null character.
"data" is a pointer, you cannot compare directly a pointer to a value.
If "data" is a cstring, you can use strcmp() to compare:
if (strcmp(data, "H")) {
If not, you will have to test each element in "data".
Be aware, though, that 0 (false) means that the strings DO match.
PaulS:
Yes. My bad. It should be:
if (strcmp(data, "H") == 0) {
Brilliant! Thats working perfectly now. If i'd have known what to search for in the forums I could have probably had something working.
Thanks for the help.
Now to get it transmitting back...
