EtherCard webClient DNS Fail
So I've set up the ENC28j60 module and got the webclient example running good.
Problem is when I change
char website[] PROGMEM = "www.google.com";
with the ip for my local server
char website[] PROGMEM = "192.168.1.98";
I receive a dns failure.
I'm hoping this is a really simple fix but I can't for the life of me work thing one out.
Any help would be great, Thank you!
That is the correct response from a dns server for that IP address. If you use nslookup, it returns "non-existent domain".
You should use an IP rather than a dns resolution for the server.
edit: For example with the w5100 library
// this uses dns
char server[] = "192.168.0.92";
// this does not
IPAddress server(192,168,0,92);
// and this does not
byte server[] = {192,168,0,92};
