Ethernet, action sur une page Web
Bonjour à tous,
J'ai reçu mon module Ethernet, relié à l'Arduino il me permet de créer une sorte de mini-serveur Web.
J'ai réussi à le faire fonctionner (du premier coup presque), voici mon code actuel :
// EtherShield webserver demo
#include "etherShield.h"
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = {192,168,1,86};
#define MYWWWPORT 80
#define BUFFER_SIZE 550
static uint8_t buf[BUFFER_SIZE+1];
// The ethernet shield
EtherShield es=EtherShield();
uint16_t http200ok(void)
  return(es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\nPragma: no-cache\r\n\r\n")));
// prepare the webpage by writing the data to the tcp send buffer
uint16_t print_webpage(uint8_t *buf)
  uint16_t plen;
  plen=http200ok();
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<html><head><title>Arduino ENC28J60 Ethernet Shield V1.0</title></head><body>"));
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><h1>Welcome to Arduino ENC28J60 Ethernet Shield V1.0</h1>"));
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<hr>
<h2><font color=\"blue\">-- Put your ARDUINO online -- "));
 Control digital outputs"));
 Read digital analog inputs HERE"));
</font></h2>") );
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</center><hr>"));
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("V1.0 <a href=\"http://www.nuelectronics.com\">www.nuelectronics.com</a>"));
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</body></html>"));
  return(plen);
void setup(){
  // initialize enc28j60
  es.ES_enc28j60Init(mymac);
  // init the ethernet/ip layer:
  es.ES_init_ip_arp_udp_tcp(mymac,myip, MYWWWPORT);
void loop(){
  uint16_t plen, dat_p;
  while(1) {
    // read packet, handle ping and wait for a tcp packet:
    dat_p=es.ES_packetloop_icmp_tcp(buf,es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf));
    /* dat_p will be unequal to zero if there is a valid
     * http get */
    if(dat_p==0){
      // no http request
      continue;
    // tcp port 80 begin
    if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
      // head, post and other methods:
      dat_p=http200ok();
      dat_p=es.ES_fill_tcp_data_p(buf,dat_p,PSTR("<h1>200 OK</h1>"));
      goto SENDTCP;
    // just one web page in the "root directory" of the web server
    if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
      dat_p=print_webpage(buf);
      goto SENDTCP;
    else{
      dat_p=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 401 Unauthorized\r\nContent-Type: text/html\r\n\r\n<h1>401 Unauthorized</h1>"));
      goto SENDTCP;
SENDTCP:
    es.ES_www_server_reply(buf,dat_p); // send web page data
    // tcp port 80 end
Ca marche nickel, quand j'accède à 192.168.1.86 j'accède bien à ma page.
Par contre je n'arrive pas bien à comprendre comment je dois adapter mon code pour par exemple récupérer la valeur d'un LM35 (température) et l'afficher en temps réél sur ma page...
Ou alors comment faire un bouton sur ma page qui me permette d'allumer une LED sur mon Arduino.
Un petit coup de pouce me permettrait de progresser dans mon projet.
Merci :slight_smile:
Je viens d'intégrer mon LM35 à mon code, je transforme la variable de récupération en String et je tente de la placer dans le code HTML mais j'obtiens cette erreur :
invalid operands of types 'char [32]' and 'const char [78]' to binary 'operator+'
Une idée ? Merci
Ayé j'ai réussi :slight_smile:
  temp = analogRead(tempPin)*0.48828125;
  dtostrf(temp,2,0,tempe);
  int i=0;
  uint16_t plen;
  plen=http200ok();
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<html><head><title>Arduino</title></head><body>"));
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><hr>
<h2>"));
  while (tempe[i]) {
                buf[TCP_CHECKSUM_L_P+3+plen]=tempe[i++];
                plen++;
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("°C
</h2>") );
  plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</center><body></html>"));
  return(plen);
