Ethernet and CNC Shield
Can i use Ethernet W1500 and CNC Shield in one board Arduino?
You have our permission to. Whether or not there are going to be pin conflicts depends on exactly which shields you are talking about. The ethernet shield uses pins 10, 11, 12, and 13. It uses other pins if you use the SD.
What pins the CNC shield uses is a mystery that you need to solve.
