ethernet and timer library together
i’ve two written two pieces of code. A piece of code to insert data to a sql database, another piece with a timer. The timer code does this; When i push on one button the led will go on for a presseted amount of time. if i press the another button the led will turn of immediately. What i want is when the timer goes off, the time that the led was on will be inserted to a database. later if i got this code right i want to control the time from a webpage but this is not for now. now my problem is the two pieces of code work fine apart, when i try to combine the code togherther my led doenst work anymore. can someone help me? Thanks in advance
code to insert to sql database
#include <Ethernet.h> // Used for Ethernet
// **** ETHERNET SETTING ****
// Arduino Uno pins: 10 = CS, 11 = MOSI, 12 = MISO, 13 = SCK
// Ethernet MAC address - must be unique on your network - MAC Reads T4A001 in hex (unique in your network)
byte mac[] = { 0x54, 0x34, 0x41, 0x30, 0x30, 0x31 };
// For the rest we use DHCP (IP address and such)
EthernetClient client;
char server[] = "192.168.0.199"; // IP Adres (or name) of server to dump data
int  interval = 5000; // Wait between dumps
  Ethernet.begin(mac);
  Serial.println("Tweaking4All.com - Temperature Drone - v2.0");
  Serial.println("-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-\n");
  Serial.print("IP Address        : ");
  Serial.println(Ethernet.localIP());
  Serial.print("Subnet Mask       : ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("Default Gateway IP: ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("DNS Server IP     : ");
  Serial.println(Ethernet.dnsServerIP());
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("-> Connected");
    // Make a HTTP request:
    client.print( "GET /add_data.php?");
    client.print("serial=");
    client.print( "02:00:00" );
    client.println( " HTTP/1.1");
    client.print( "Host: " );
    client.println(server);
    client.println( "Connection: close" );
    client.println();
    client.println();
    client.stop();
  else {
    // you didn't get a connection to the server:
    Serial.println("--> connection failed/n");
  delay(interval);
timer code
#include <RBD_Timer.h>
RBD::Timer timer;
const int buttonPin = 2;     // the number of the pushbutton pin
const int buttonPin1 = 3;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
int buttonState1 = 0;         // variable for reading the pushbutton status
int TijdHTTP = 20000;
int verstrekenTijd;
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(buttonPin1, INPUT);
  timer.setTimeout(TijdHTTP);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  buttonState1 = digitalRead(buttonPin1);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    timer.restart();
  if (buttonState1 == HIGH) {
    // turn LED on:
    timer.stop();
  if(timer.isActive()) {
    digitalWrite(ledPin, HIGH);    // sets the LED to the button's value
    verstrekenTijd = timer.getValue();
    Serial.println(verstrekenTijd);
  if(timer.isExpired()) {
    digitalWrite(ledPin, LOW);    // sets the LED to the button's value
  if(timer.isStopped()) {
code combined
RBD::Timer timer;
int verstrekenTijd;
int onOffVariable = 0;
    // turn LED on:
    timer.restart();
    // turn LED on:
    timer.stop();
    onOffVariable = 1;
    if ( onOffVariable == 1 ) {
    client.print( TijdHTTP );
    client.println();
    client.println();
    client.stop();
    onOffVariable = 0;
  client.stop();
  delay(interval);
notice anything here:
that is in common with this:
thanks for you reaction. I changed it to normal integers, but the problem isn't solved
sebastiaan_maes:
hmmmm....
It doesn't matter if you refer to them as 8bit, 16 bit or even 64 bit...
How do you suppose you can use pin 13 for SPI/Ethernet and be flashing a LED connected to the same pin?
i changed the output pin to pin 5, no result :frowning:
Please post your updated combined code.
RBD::Timer timer;
int Output =  5;      // the number of the LED pin
int verstrekenTijd;
  pinMode(Output, OUTPUT);
  //Ethernet.begin(mac);
    // turn LED on:
    timer.restart();
    // turn LED on:
    timer.stop();
    digitalWrite(Output, HIGH);    // sets the LED to the button's value
    digitalWrite(Output, LOW);    // sets the LED to the button's value
    client.print( "Thomas" );
    client.print("&");
    client.print("temperature=");
    client.print( "12:00:00" );
    client.println();
    client.println();
    client.stop();
  else {
