Ethernet and UDP, correct connection practice
Hello, On an Arduino Ethernet I've got a remote sensor app that connects to the internet once a day to get the time from a time server, then once a week posts the sensor readings.
My question is about correct connection practices and, unfortunately, I don't know that much about the inner workings of network transport.
So all the sample code I've found puts these two lines:
  if (Ethernet.begin(mac))
    if (Udp.begin(localPort))
in the setup and then makes the various network calls in the loop. But I think that assumes constant use of the connection. My use of the connection is once a week and, after a few days, my connections fail.
Ideally I'd like to have an Ethernet.end and a Udp.end so I can put the .begin and .end in the loop at the time I want to make the connection, but those calls aren't available.
Can you please tell me what the proper method is to make a connection once a day and ensure that the connection does not fail?
I can post more code here if you'd like.
Thank you,
DougM
