Ethernet Begin Hanging
Hi I have an arduino mega with ethernet2 shield when it reaches the Ethernet.begin it doesn't seem to go any further I have tried this on another arduino mega and the same issue happens. I have loaded the Ethernet webclient example and this works fine.
I have 3 mux's wired in as well on my test arduino it was just the Ethernet Shield attached.
here is my code I am quite puzzled.
     #define NUM_ZONES (63)
     #include <SPI.h>
     #include <Ethernet2.h>
     #include  <SD.h>
     #include <IniFile.h>
     #include "MUX74HC4067.h"
     // Creates a MUX74HC4067 instance
     // 1st argument is the Arduino PIN to which the EN pin connects
    // 2nd-5th arguments are the Arduino PINs to which the S0-S3 pins connect
    MUX74HC4067 mux1(22,23,24,25,26);
    MUX74HC4067 mux2(28,29,30,31,32);
    MUX74HC4067 mux3(48,49,50,51,52);
     //check the mac address
     // spare arduino mac addres
     byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
      // arduino mac addres
     //byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0x3D, 0xFB };
     byte ip[] = {192,168,0,177};
     EthernetClient client ;
    // The select pin used for the SD card
    #define SD_SELECT 4
    #define ETHERNET_SELECT 10
    //arrays to check if button has changed
   //int previousState[NUM_ZONES]=  {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
    int previousState[NUM_ZONES]= {1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1};
    //Command to pass to homeseer
    char* myStrings[64];
    //SubRoutine For Error Messages Reading SD card
    void printErrorMessage(uint8_t e, bool eol = true)
    switch (e) {
    case IniFile::errorNoError:
     Serial.print("no error");
     case IniFile::errorFileNotFound:
     Serial.print("file not found");
     case IniFile::errorFileNotOpen:
     Serial.print("file not open");
     case IniFile::errorBufferTooSmall:
     Serial.print("buffer too small");
     case IniFile::errorSeekError:
     Serial.print("seek error");
     case IniFile::errorSectionNotFound:
     Serial.print("section not found");
     case IniFile::errorKeyNotFound:
     Serial.print("key not found");
     case IniFile::errorEndOfFile:
     Serial.print("end of file");
  case IniFile::errorUnknownError:
    Serial.print("unknown error");
  default:
    Serial.print("unknown error value");
  if (eol)
  //Config and read SD card
  // Configure all of the SPI select pins as outputs and make SPI
  // devices inactive, otherwise the earlier init routines may fail
  // for devices which have not yet been configured.
  digitalWrite(ETHERNET_SELECT, HIGH); // disable Ethernet
  const size_t bufferLen = 80;
  char buffer[bufferLen];
  const char *filename = "/config.ini";
  SPI.begin();
  if (!SD.begin(SD_SELECT))
    while (1)
      Serial.println("SD.begin() failed");
  IniFile ini(filename);
  if (!ini.open()) {
    Serial.print("Ini file ");
    Serial.print(filename);
    Serial.println(" does not exist");
    // Cannot do anything else
    while (1)
  Serial.println("Ini file exists");
  // Check the file is valid. This can be used to warn if any lines
  // are longer than the buffer.
  if (!ini.validate(buffer, bufferLen)) {
    Serial.print("ini file ");
    Serial.print(ini.getFilename());
    Serial.print(" not valid: ");
    printErrorMessage(ini.getError());
    while (1)
 // Fetch a value from a key which is present
 // get data from sd card and write to array
Serial.println("getting Homesser commands");
   for (int j=0; j<=63; j=j+1) {
        char mpass[ ] = "command"  ;
        int num = j;
        char cstr[16];
        itoa(num, cstr, 10);
        strcat(mpass,cstr);
        if (ini.getValue("HSCOMMANDS",mpass, buffer, bufferLen)) {
        myStrings[j] = buffer;
// Configures how the SIG pin will be interfaced e.g. The SIG pin connects to PIN 3 on the Arduino and PIN 3 is a digital input
mux1.signalPin(27, INPUT, DIGITAL);
mux2.signalPin(33, INPUT, DIGITAL);
mux3.signalPin(53, INPUT, DIGITAL);
Serial.println("loaded ini");
//Network card setup
digitalWrite(ETHERNET_SELECT, LOW); // enable Ethernet this is turned on after SD reader finished with SPI pins
Serial.println("Turning Ethernet on");
digitalWrite(SD_SELECT, HIGH); // Disable SD card
Serial.println("Disabled SD card");
Ethernet.begin(mac, ip);
Serial.println("ready");
Serial.println("waiting for button press");
byte data;
String hsCommand;
String mypass;
  for (byte i = 0; i < 48; ++i)// was 16
    // Reads from channel i and returns HIGH or LOW
    if (i < 16){
    data = mux1.read(i);
    //Serial.print("MUX1 Push button at channel ");
    else if (i >15 and i <32){
    data = mux2.read(i-16);
    //Serial.print("MUX2 Push button at channel ");
    else if (i >31){
    data = mux3.read(i-16);
    //Serial.print("MUX3 Push button at channel ");
//tmp not to include in final version
 Serial.print("posistion ");
  Serial.print(i);
  Serial.print("value ");
  Serial.println(data);
    if ((data == HIGH) && (previousState[i] == LOW ))  {
              //call homeseerpost turning on
              Serial.println("in on if statement");
              mypass = String(myStrings[i]) + "&label=off";
              //mypass =  "347&label=off";
              Serial.println(mypass);
              sendHomeSeerCommand(mypass);
    else if ((data == LOW) && (previousState[i] == HIGH )) {
            // call homeseerpost turning off
            Serial.println("in Off if statement");
            mypass = String(myStrings[i]) + "&label=on";
            //mypass = "347&label=on";
    previousState[i] = data;
  // this to remove
  void sendHomeSeerCommand(String HScommand)
    byte server[] = { 192,168,0,2 };
    String url = "/JSON?request=controldevicebylabel&ref=" + HScommand ;
    int ret = client.connect(server, 80) ;//was 8080
     if (ret==1)
       Serial.println("Sending " + url);
        client.print("GET " + url + " HTTP/1.1\r\n" +
                     "Host: 192.168.0.2 " + "\r\n" +
                     "Connection: close\r\n\r\n");
                     client.stop();
    else {
    Serial.println("connection failed");
use the Arduino Ethernet library, the latest version 2.00. Try the examples. They detect problems in setup().
What MAC address are you using in the client example that worked?
the Erhernet shield uses SPI pins 50, 51 and 52. you can't use them for mux
