Hi
I am new to Arduino coding although I have done a fair bit of C# and Python over the years as well as Html and Javascript so I have an understanding of the code, but this problem has me stumped without the debuging I am used to.
I have an Arduino Mega 2560 Rev3 with an Ethernet Sheild Rev3 compatable and my code is as follows
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte dns[] = {8, 8, 8, 8};
byte ip[] = {192, 168, 1, 3};
byte gateway[] = {192, 168, 1, 254};
byte subnet[] = {255, 255, 255, 0};
EthernetServer server = EthernetServer(80);
#define Led 52
//Ethernet.begin(mac, ip, dns, gateway, subnet);
//server.begin();
pinMode(Led , OUTPUT);
digitalWrite(Led , HIGH);//turn the LED On by making the voltage HIGH
delay(500); // wait half a second
digitalWrite(Led , LOW);// turn the LED Off by making the voltage LOW
The above code works as expected and the Led flashes however if I uncomment this line of code
the led will not work it just does nothing, I have also tried
Ethernet.begin(mac, ip, gateway, subnet); same result.
If I add code to access the web page at 192.168.1.3 everything works fine and I can print the result of commands I send to be executed but
will not switch the Led either HIGH or LOW when I send the command to the web page to switch the led with this line of code,
uncommented which of course needs to be included to be able to comunicate with the Arduino via ethernet.
Thanks in advance any help is much appreciated.
Neil
