Ethernet Bonjour and issues with the ENC28J60
Hi, I am looking for some info to point me in the right direction.
I have an ENC28J60 connected to an Arduino Mega and would like to make the device broadcast a service using bonjour.
The first issue I ran into was that the default Ethernet library supplied with the Arduino IDE won't start a connection using the ENC28J60. When I call Ethernet.begin() it just freezes and doesn't even return an error, which makes my think i have it weird wrong for the library to work correctly. I have also tried different wiring without any avail.
Second I tried the UIPEthernet library which works fine however as far as I am aware it does not support multicast thus mDNS won't be possible, so I then moved to the EtherCard library which does support multicast and I implemented the EtherCard-MDNS library, It returns true when starting the mDNS responder however i couldn't get my Mac to access the .local url and it doesn't appear when using a bonjour browser. I also have reservations of using the EtherCard-MDNS library as it seems to have been abandoned.
I would prefer to use the default ethernet library if at all posable as there is the EthernetBonjour library which seems to be well supported.
So here are my questions:
  • Should the ENC28J60 work with the default lib?
  • If so what could be the issue causing it not to connect?
  • Am I wright in thinking that the UIPEthernet library won't work for mDNS?
  • Would I be better off switching to a W5100?
Thanks.
The Ethernet library that comes with the IDE is NOT for the ENC28J60. It only works with ethernet shields with W5100 chips.
No.
Absolutely.
Cool thanks, I actually ended up ordering a W5100 yesterday anyway.
