I have googled and searched these forums and cannot find any reference of my error code.
If I wait for "client" to return true, the program waits forever (from http://arduino.cc/en/Reference/IfEthernetClient)
while(!client){
If I skip that and try to connect anyway, I get a connection result of -5.
int ret = client.connect(serverName, 6990);
if (ret == 1) {
Serial.println("Connected");
client.println("GET /index.html");
client.println();
else {
Serial.println("Failed to connect ");
Serial.println(ret);
Serial.println(client.status());
Does anyone know what that error code means? Is the shield bunk? Is it a PIN conflict, I am very new to arduino, but have tried many examples and they all seem to have the same result.
My Router shows the MAC and hostname with a valid lease:
90:a2:da:0d:4e:71 192.168.000.007 255.255.255.000 D:00 H:08 M:53 S:20 Sat Sep 08 04:37:11 2012 WIZnet0D4E71
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
modified 9 Apr 2012
by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x4E, 0x71 };;
IPAddress server(173,194,33,104); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
Serial.println("Obtaining local IP");
IPAddress myIPAddress = Ethernet.localIP();
Serial.println(myIPAddress);
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.0");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
result:
connecting...
Obtaining local IP
192.168.0.7
connection failed
-5
0
disconnecting.
