Ethernet Client connections
I'm trying to get a handle on Ethernet client connections. I'm using the Ethernet.h library with the standard Ethernet shield (R3). I've seen this code is several Ethernet examples:
// if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    Serial.println("disconnecting.");
    client.stop();
This doesn't seem to work very well for me, I have a sketch (you can see it here: http://pastebin.com/xxYkGqqm) doing an HTTP POST to pushingbox.com and frequently this if() statement doesn't go true and doesn't disconnect.
One thing I don't really understand is the distinction between being connected and client.stop(). If client.connected() is false it means I'm not connected to the server, right? So why do I still need the client.stop() statement? I've noticed if the client.stop() is not executed the Ethernet connection can get hung up or something - meaning I try to POST, but it's not successful.
I've seen another example where client.stop() is implemented like this:
while( client.connected() ) {
  while(client.available()) {
    inChar = client.read();
    Serial.write(inChar);
    connectLoop = 0;
  delay(1);
  connectLoop++;
  if(connectLoop > 1000) {
    Serial.println(F("Timeout"));
    client.stop();
This seems more reliable in getting the client.stop() to execute. I'd like to better understand how all this works and what people recommend for a reliable way to implement HTTP POST.
I use that second example you mentioned. It is in both my GET and POST method examples in the playground. http://playground.arduino.cc/Code/WebClient
It has a timeout feature that prevents the "while(client.connected())" loop from becoming an endless loop if the server stalls or the connection breaks. That is the function of the connectLoop variable.
