Ethernet client does not connect with local server
Hello everyone,
I am trying to make a simple connection between my Arduino and a local server(using express in nodejs) running on my laptop and both are connected directly, without a router or switch. However it always fails.
I catched the return value from ''client.connect(server, 8080)'' It is always "connection failed".
I've tried a different EthernetSield and cable.
Thanks so much to everyone!
My code:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(169,254,188,3); //local ip
IPAddress server(169,254,191,189); //ip where server is running
EthernetClient client;
  Serial.println("Starting...");
  Ethernet.begin(mac,ip);
  if (client.connect(server, 8080)) {
    Serial.println("connected");
    Serial.println("connection failed");
  Serial.println(Ethernet.localIP());
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
does the WebClient example run?
can you ping the Ethernet board from the PC?
make sure your static IP addresses are on the same subnet
I connected an EthernetSheildV1 direct to a Windows 10 PC setting the Win10 Ethernet static IP to 192.168.1.115
ran following program on Arduino Uno with EthernetSheildV1
// TCPcharClient.ino - a simple TCP chat program
// not using DHCP so check subnet address range is correct
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0E, 0xD0, 0x93 };
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 1,115);
IPAddress myDns(192, 168, 1,254);   // DNS server
// Initialize the Ethernet client library
byte server[] = { 192, 168, 1, 10 }; // server IP address
int serverPort=10000;                // server TCP port (open any firewall on server)
  Serial.begin(115200);   // Open serial communications and wait for port to open:
  while (!Serial) ;
  // start the Ethernet connection:
  Serial.println("\n\nInitialize Ethernet (not using DHCP) :");
  Ethernet.begin(mac, ip);
  Serial.println("connecting to server...");
  // Ethernet ready, connect to server and transmit data
  if (!client.connect(server, serverPort)) {
     while(1);
  Serial.println("connection OK");
// chat server open
//   transmit text entered at keyboard to server
//   display text received from server
  char ch;
  static  String receivedLine = "", transmitLine="";
    if((ch = client.read()) != '\n')
          receivedLine+=ch;                // add to currentline
    else {
          Serial.println("Received '" + receivedLine + "'");
          receivedLine="";
  if(Serial.available())                // if keyboard test available
    if((ch=Serial.read()) != '\n')      // if not new line
         transmitLine+=ch;  // add to currentline
    else  {                               // on \n transmit line
        Serial.println("transmitting '" + transmitLine + "'");
        client.print(transmitLine + "\n");
        transmitLine="";
ran the Java TCPchat server from post #6 on the PC
arduino output
192.168.1.115
connection OK
transmitting 'cient test 1'
transmitting '22222222222222222222'
Received 'server test 1
Received '22222222222222222
Received '
transmitting 'client bye'
Received 'server bye
the server displayed
direct_connection_test
@Juraj I got the code from ArduinoHttpClient and I used it over the Ethernet library.
var express = require('express');			// include express.js
var app = express();						// a local instance of it
var bodyParser = require('body-parser');	// include body-parser
var WebSocketServer = require('ws').Server	// include Web Socket server
// you need a  body parser:
app.use(bodyParser.urlencoded({extended: false})); // for application/x-www-form-urlencoded
// this runs after the server successfully starts:
function serverStart() {
	var port = server.address().port;
	console.log(server.address());
// this is the POST handler:
app.all('/*', function (request, response) {
	console.log('Got a ' + request.method + ' request');
	// the parameters of a GET request are passed in
	// request.body. Pass that to formatResponse()
	// for formatting:
	console.log(request.headers);
	if (request.method == 'GET') {
		console.log(request.query);
		console.log(request.body);
	// send the response:
	response.send('OK');
	response.end();
// start the server:
var server = app.listen(8080, serverStart);
// create a WebSocket server and attach it to the server
var wss = new WebSocketServer({server: server});
wss.on('connection', function connection(ws) {
	// new connection, add message listener
	ws.on('message', function incoming(message) {
		// received a message
		console.log('received: %s', message);
		// echo it back
		ws.send(message);
ip
I ask if the simplest example work to rule out basic problems
@Juraj, only works when the arduino is the service and the node is the client. Follow bellow:
Arduino
#include <SPI.h>
/* ETHERNET VARIABLES */
byte ip[] = {169,254,188,3};
EthernetServer server = EthernetServer(9023);
  SPI.begin();
  Ethernet.begin(mac,ip); // init EthernetShield
  server.begin();
  if(server.available()){
    Serial.println("Client available");
    Serial.println("Client not avaliable");
  server.write("test");
    receiveResponseFromServer(client);
    String message = client.readStringUntil('\n');
    Serial.println(message);
void receiveResponseFromServer(EthernetClient client){
  Serial.print("Response -> ");
Node.JS
var net = require('net');
const ip = '169.254.188.3';
const port = 9023;
var client = new net.Socket();
client.connect(port, ip, function () {
  console.log('Connected');
client.on('data', function (data) {
  console.log(data);
  client.write('ok\n');
client.on('close', () => {
   client.connect(port, ip);
client.on('error', function (err) {
  console.log("Error: " + err.message);
  //client.connect(port, ip);
this will only work if you are using a subnet mask like 255.255.0.0
I assume this is uncommon.
Please post the ipconfig of your laptop (=the server) including the subnet mask.
then fit the ip of your Arduino to the IP range of your server (or in other words - only the last IP octet should differ if you have a subnet mask of 255.255.255.0).
try a 500 milliseconds delay between Ethernet.begin(mac,ip); and if (client.connect(server, 8080)) {
@noiasca Follow below:
ipconfig
Thank you!
@Juraj Didn't works :frowning:
try wireshark to monitor traffic on the network
you have to specify the network mask if it is not 255.255.255.0
IPAddress gw(169,254,188,1);
Ethernet.begin(mac, ip, gw, gw, IPAddress(255, 255, 0, 0));`
Niceeeeee @Juraj it works!! :clap: :clap: :clap: :clap:
