Ethernet Client & Server in the same sketch
Hi
Before I set off down this route I wanted to check if I could run an Ethernet Client & Server in the same sketch or would this cause problems?
I am currently running a sketch with PID loop controlling actuators and reporting to ThingSpeak for remote logging purposes. I would now like to be able to change parameters remotely hence my thought that instigating a server in the sketch may be the way forward but something doesn't seem right so am looking for a nudge in the correct direction!!!!
That is no problem if you have an Arduino Mega 2560 + Ethernet Shield. You can run a few other services as well. There might be a delay, since the sketch can only process one at a time. I hope you are not trying to do this with an Arduino Uno + Ethernet Shield, that runs out of memory very quick. What do you have at the moment ? I2C LCD, ThingSpeak, Ethernet, Servo, PID. Maybe you want to add SD later.
On my Mega + Ethernet, I have running for the W5100 : EthernetServer (webpages + website on SD card), Adafruit_IO (not working yet), FTP client, NTP client to retrieve the date and time, ThingSpeak, E-mail (send emails), and maybe a few more. Only the EthernetServer is declared as a global variable, the others create a EthernetClient on the stack when it is needed. But it will is also work when every task uses its own global EthernetClient, and even when the tasks all use a single global EthernetClient (but not at the same time).
That is no problem
Really? Handling GET requests, and making GET requests won't interfere with the PID loop?
You have asked two questions. Yes, client/server code can be included in the same sketch. As to causing problems, that would depend on what going on in the rest of your code.
Yes I am using an Arduino Mega 2560 + Ethernet Shield ....I have already exhausted the capabilities of the UNO it appears!!
Correct I am running. What do you have at the moment ? I2C LCD, ThingSpeak, Ethernet, Servo, PID.
Is there anything I need to be careful of? Do I just need to close the client connection before opening the server connection on each loop?
Koepel.....any chance we could see your code....sounds like the bees knees. :)
You can keep the server open, as well as the client.
My code is a code from tutorials, that I put in seperate 'tabs'. They become seperate *.ino files in my project.
