Hi, I'm tried to connect to apache on my Win10 notebook. I want to catch the php in apache. But the question is it doesn't connect success everytime. Also, I tried to connect to Google. It doesn't connect everytime too, but the connect success times is much better than apache.
Here is the version :
apache 2.4.41
arduino 1.8.12
MEGA 2560
Enternet W5100
Here is the code
#include <Ethernet.h>
#include <SPI.h>
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
#include <avr/pgmspace.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 10, 3 };
byte gateway[] = { 192, 168, 10, 254 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte server[] = { 192, 168, 10, 2 }; //64, 233, 187, 99
//char server[] = "www.google.com";
EthernetClient client;
hd44780_I2Cexp lcd; //宣告lcd
Ethernet.begin(mac, ip);
lcd.init(); // initialize the lcd
lcd.noBacklight();
delay(300);
lcd.backlight(); //開啟背光
Serial.println("connecting...");
if (client.connect(server, 80)) {
Serial.println("connected");
client.println("GET /php2arduino/test.php HTTP/1.0");
client.println();
Serial.println("connection failed");
lcd.setCursor(0, 0);
if (client.available()) {
String d= client.readStringUntil('\n');
Serial.print (d+'\n');
lcd.print(d);
lcd.init();
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
for(;;)
Here is the result to connect apache. Try 4 times, only first connect success .
connecting...
connected
HTTP/1.1 200 OK
Date: Fri, 24 Apr 2020 07:08:39 GMT
Server: Apache/2.4.41 (Win64) PHP/7.3.12
X-Powered-By: PHP/7.3.12
Content-Length: 3
Connection: close
Content-Type: text/html; charset=UTF-8
UFO
disconnecting.
connecting...
connection failed
disconnecting.
connecting...
connection failed
disconnecting.
connecting...
connection failed
disconnecting.
I have look for the past topic, some said it cause by memory problem that I should avoid use string.
But I can't use F() on GET the HTTP. Or maybe there has a way to replace readStringUntil ?
I'm a beginner, so hope get some example help.
Thank for your kind!
