Hi Andy
FWIW, you can simplify the code by using millis() instead of the timer1 code. There is also a dateTime library in the playground that makes this even easier and you can use this to do the conversion from NTP time.
If you are interested, here is some code that uses the ENC28j60 Ethernet shield to sync the dateTime library.
// NTP Tiny
#include <enc28j60.h>
#include <etherTiny.h>
#include <ip_arp_udp_tcp.h>
#include <net.h>
#include <DateTime.h> // mem's Date and Time library from the Arduino Playground
static uint8_t mymac[6] = { 0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = { 192,168,1,15};
static uint8_t gwip[4] = { 192,168,1,254}; // gateway
static char baseurl[]="http://192.168.1.15/";
static uint8_t ntpclientportL=0;
// --------------- NTP servers------
static uint8_t ntpip[4] = { 17,254,0,31}; // time.apple.com (any of 17.254.0.31, 17.254.0.26, 17.254.0.27, 17.254.0.28):
int8_t hours_offset_to_utc = 1;
time_t prevNtpReq = 0; // time last ntp request sent
boolean haveGWip = false;
#define BUFFER_SIZE 560
static uint8_t buf[BUFFER_SIZE+1];
#define STR_BUFFER_SIZE 22
static char strbuf[STR_BUFFER_SIZE+1];
EtherTiny es = EtherTiny();
void processNtpState(){
// if ( es.linkUp() ){ // link up ?
if( enc28j60linkup()){
if (haveGWip == false){ // have gateway IP ?
Serial.println("waiting for GW IP");
es.client_arp_whohas(buf,gwip);
else if ( DateTime.available() == false) { // never been synced ?
if( (prevNtpReq == 0) || (prevNtpReq + 10 < DateTime.now()) ){
// send out initial request
ntpclientportL++;
Serial.println("req init NTP sync");
es.client_ntp_request(buf,ntpip,ntpclientportL);
prevNtpReq += 10;
else if( prevNtpReq + 60 < DateTime.now() ){ // synced over 1 hr ago
Serial.println("req NTP update");
ntpclientportL++;
Serial.println(prevNtpReq,DEC);
prevNtpReq += 60; // schedule another request in 1 min (irrespective of whether a response received or not)
Serial.print(DateTime.now(),DEC);
else{
Serial.println("Eth-link down");
void setup(){
Serial.begin(19200);
enc28j60Init(mymac);
enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
delay(10);
enc28j60PhyWrite(PHLCON,0x476); // 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
delay(100);
init_ip_arp_udp_tcp(mymac,myip,80); //init the ethernet/ip layer:
void timeDigitToString(uint8_t value, char seperator, char * destination){
// utility to write the string representation of the given value to the destination, values should be 0-59
if( value < 10)
destination[0] = '0'; // pad with zero if single digit
destination[0] = '0' + value / 10; // most significant digit of value
destination[1] = '0' + value % 10; // least siginificant digit of value
destination[2] = seperator;
destination[3] = 0; // null terminate
char * timeNowToString(){
// convert the time now to a srting of the form "hh:mm:ss "
static char timestr[10];
DateTime.available();
timeDigitToString(DateTime.Hour, ':', ×tr[0] );
timeDigitToString(DateTime.Minute, ':', ×tr[3] );
timeDigitToString(DateTime.Second, ' ', ×tr[6] );
return timestr;
void sendTCP(unsigned int plen){
es.make_tcp_ack_from_any(buf); // send ack for http get
es.make_tcp_ack_with_data(buf,plen); // send data
void processPacket(uint16_t plen){
uint16_t dat_p;
byte on_off = 1;
int8_t cmd;
// arp is broadcast if unknown but a host may also verify the mac address by sending it to a unicast address.
if(es.eth_type_is_arp_and_my_ip(buf,plen)){
if (es.eth_type_is_arp_req(buf)){
es.make_arp_answer_from_request(buf);
if (es.eth_type_is_arp_reply(buf)){
if (es.client_store_gw_mac(buf,gwip)){
haveGWip=1;
if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
es.make_echo_reply_from_request(buf,plen); // its a ping so do reply
Serial.print("Got ping: ");
Serial.println(timeNowToString());
if (buf[IP_PROTO_P]==IP_PROTO_UDP_V&&buf[UDP_SRC_PORT_H_P]==0&&buf[UDP_SRC_PORT_L_P]==0x7b){
time_t time = 0;
if (es.client_ntp_process_answer(buf,&time,ntpclientportL)){
// convert to unix time:
if ((time & 0x80000000UL) == 0)
time += 2085978496; // 7-Feb-2036 @ 06:28:16 UTC it will wrap:
time -= GETTIMEOFDAY_TO_NTP_OFFSET; // from now until 2036:
time += (hours_offset_to_utc * 3600L);
Serial.print("Got Time packet: ");
DateTime.sync(time); // set the internal clock
prevNtpReq = time;
void loop(){
uint16_t plen;
plen = enc28j60PacketReceive(BUFFER_SIZE, buf);
/* plen will be unequal to zero if there is a valid packet (without crc error) */
if(plen!=0)
processPacket(plen);
processNtpState();
