I have tried to establish communication between Arduino and OPC Server via serial mode and it's working fine. Now I am trying to establish Ethernet communication but not able to do it.
below I am attaching the code and screenshots.
Kindly guide me regarding the same.
Thanks in advance!
#include <SPI.h>
#include <Ethernet.h>
#include <OPC.h>
OPCSerial aOPCSerial;
int ledPin = 13;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] =
0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE1
IPAddress ip(192, 168, 192, 159);
// telnet defaults to port 23
EthernetServer server(23);
bool callback2(const char *itemID, const opcOperation opcOP, const bool value)
static bool ledValue = false;
if (opcOP == opc_opwrite)
ledValue = value;
if (ledValue == HIGH) {
digitalWrite(ledPin, HIGH);
Serial.println("HIGH");
else {
digitalWrite(ledPin, LOW);
Serial.println("LOW");
return ledValue;
Ethernet.init(10);
// initialize the ethernet device
Ethernet.begin(mac, ip);
pinMode(ledPin, OUTPUT);
aOPCSerial.setup();
aOPCSerial.addItem("DO1", opc_readwrite, opc_bool, callback2);
aOPCSerial.processOPCCommands();
There was a problem in program. I was trying to connect via ETHERNET protocol using Syntax of Serial in the program. I am attaching the code below.
But, This is also working for COM tab not for UA.
kindly enlighten me regarding what I have to do for UA.
Thank you in advance!
#include <OPC.h>
#include <Bridge.h>
#include <SPI.h>
OPCEthernet OPCE;
int p1;
int inputpin=8;
int ledPin = 13;
byte mac[] ={0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE1};
IPAddress ip(192, 168, 192, 157);
//IPAddress myDns(8, 8, 8, 8);
//IPAddress gateway(192, 168, 192, 1);
IPAddress subnet(255, 255, 255, 0);
const int listen_port = 4840;
//EthernetServer server(80);
bool i1(const char *itemID, const opcOperation opcOP, const bool valor)
p1= digitalRead(inputpin);
return p1;
bool o1(const char *itemID, const opcOperation opcOP, const bool valor)
static bool valor_led = false;
valor_led = valor;
if (valor) {
else {
return valor_led;
pinMode(inputpin, OUTPUT);
OPCE.setup(listen_port,mac,ip);
OPCE.addItem("DIGITAL_OUTPUT", opc_readwrite, opc_bool, o1);
OPCE.addItem("DIGITAL_INPUT", opc_readwrite, opc_bool, i1);
OPCE.processOPCCommands();
Hello,
This OPC.h library does not contain any function related UA.
Anyone know about any library for OPC UA or how to use OPC UA protocol for Arduino please guide me.
Thanks in advance!
I don't know where you have a tab here. OPC is using COM for the communication with your Windows device so you might have the term COM from there. But I haven't found out what you mean by "UA" in this context.
