Ethernet ENC28J60
Hello every one,
I am trying to use Ethernet ENC28J60 module , already downloaded the ethercard , and follow an example about how to connect the Ethernet with Arduino and every thing is OK in serial monitor
but my problem is , when i entered the IP address to the webpage , it didn't work , I mean the message that appear in serial monitor did not appear in webpage ... is there any supported program i need ?
thank you
you should show us your code..
I followed this tutorial.
have you tried a package such as Wireshark to check the packets on the network?
