Bonjour,
j'utilise le shield ethernet pour que l'arduino dans le rôle du serveur affiche un site depuis la carte sd
code arduino :
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xF3, 0x9B }; //adresse mac de votre carte
byte ip[] = {192, 168, 0, 16}; //adresse IP
EthernetServer server(80); // create a server at port 80
File webFile;
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("confort.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
code html :
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<title>confort</title>
<link rel="stylesheet" type="text/css" href="style.css">
</head>
<body>
<header><h1 id="titre">
Gérer le confort
</h1></header>
<div id ="menu">
<table>
<tr>
<td name="tab1">acceuil</td>
<td name="tab1">confort</td>
<td name="tab1">sécurité</td>
</tr>
</table>
</div>
<nav>
<div id="champ1">
<p class="flotte">
<img src="logo.png" alt="Nouveau !" />
</p>
<h2 id="titre2">
L'éclairage
</h2>
<input type="checkbox" id="lampe_ext1" name = "boite" >
<label for="boite" id="texte_lampe_ext1" class="rouge"></label><img src="rien.jpg" alt ="ext1 " name="1" id ="image1">
<input type="checkbox" id="lampe_ext2" name = "boite" >
<label for="boite" id="texte_lampe_ext2" class="rouge"></label><img src="rien.jpg" alt ="ext2 " name="1" id ="image2" >
<input type="checkbox" id="lampe_maison" name = "boite" >
<label for="boite" id="texte_lampe_maison" class="rouge"></label><img src="rien.jpg" alt ="maison " name="1" id ="image3" >
<input type="checkbox" id="lampe_studio" name = "boite" >
<label for="boite" id="texte_lampe_studio" class="rouge"></label><img src="rien.jpg" alt ="studio " name="1" id ="image4" >
</div>
<div id="champ2">
<p class="flotte">
<img src="logo2.png" alt="Nouveau !" />
</p>
<h2 id="titre3">
Le chauffage
</h2>
<input type="checkbox" id="chauffage_salon" name = "boite" >
<label for="boite" id="texte_chauffage_salon" class="rouge"></label><img src="rien.jpg" alt ="ext1 " name="1" id ="image5">
<input type="checkbox" id="chauffage_chambre" name = "boite" >
<label for="boite" id="texte_chauffage_chambre" class="rouge"></label><img src="rien.jpg" alt ="ext2 " name="1" id ="image6" >
<input type="checkbox" id="chauffage_studio" name = "boite" >
<label for="boite" id="texte_chauffage_studio" class="rouge"></label><img src="rien.jpg" alt ="maison " name="1" id ="image7" >
</div>
</nav>
<section>
<div id="parent">
<img src="maison.png" class ="superpose" alt ="maison " name = "2" id ="maison">
<img src="maison1.png" class ="superpose" alt ="lampe1 " name = "2" id ="maison1">
<img src="maison2.png" class ="superpose" alt ="lampe2 " name = "2" id ="maison2">
<img src="maison3.png" class ="superpose" alt ="lampe3 " name = "2" id ="maison3">
<img src="maison4.png" class ="superpose" alt ="lampe4 " name = "2" id ="maison4">
<img src="maison5.png" class ="superpose" alt ="radiateur1 " name = "2" id ="maison5">
<img src="maison6.png" class ="superpose" alt ="radiateur2 " name = "2" id ="maison6">
<img src="maison7.png" class ="superpose" alt ="radiateur3 " name = "2" id ="maison7">
</div >
</section>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="domotique.js"></script>
</body>
</html>
$(function(){
$('#lampe_ext1').change( function() {
if( $('#lampe_ext1').is(':checked') )
{$('#texte_lampe_ext1').removeClass('rouge').addClass('vert');
$('#texte_lampe_ext1').html('extérieur allumé.');
$('#image1').attr('src','allume.png');
$('#maison').attr('src','maison.png');
$('#maison1').css('z-index' , '101');
{ $('#texte_lampe_ext1').html('extérieur eteint.');
$('#texte_lampe_ext1').removeClass('vert').addClass('rouge');
$('#image1').attr('src','rteint.png');
$('#maison1').css('z-index' , '99');
sur mon navigateur depuis mon pc ça marche mais depuis l'arduino les images n'apparaissent pas
problème de capacité de l'arduino?
mais quelle est la question ? (votre code Arduino ne répond qu'à une seule requête HTPP toujours de la même façon avec confort.htm quelle que soit la requête ? c'est louche)
votre souci comme je le dis plus haut c'est que quand le navigateur reçoit la page principale en HTML il doit demander toutes les autres resources au serveur... et vous ne servez jamais ces autres resources (logo.png, logo2.png, maison.png, ...) --> faut détecter la requête reçue sur l'Arduino et envoyer la resource demandée pas juste la page générique standard HTML à chaque fois. (imprimez ce que le GET vous demande vous verrez sans doute passer pleins de requêtes)
Après quelques recherche, je me rends effectivement compte qu'il est nécessaire, d'analyser la requete get. Afin de simplifier le travail, j'impose que chaque page html soit enregistrée sous h01.htm, h02.htm...De la même façon les images sont enregistrées sous I01.png, I02.png. dANS LE PROGRAMME on sauvegarde la premiere ligne du client avec sa requète get dans un buffer, puis :
on analyse le 9eme caractère afin de connaitre le type : si h alors html, si p alors png etc..
puis on examine le 7eme caractère afin de connaitre le numéro de page ou d'image (limité à 10)
#include <SPI.h>
#include <SD.h>
#define REQ_BUF_SZ 20// buffer pouvant accueillir la requete get de taille 20 car le nom a 3 caractere max et l'extension aussi
IPAddress ip(192, 168, 0, 16);//adresse ip locale
// IP address, may need to change depending on network
File webFile;
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
// disable Ethernet chip
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
if (!SD.begin(4)) {
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c;// save HTTP request character
req_index++;
// print HTTP request character to serial monitor
Serial.print(c);
Serial.println(HTTP_req[7]);
Serial.println(HTTP_req[9]);
// open requested web page file
if (StrContains(HTTP_req, "GET / ")
|| (HTTP_req[9] == 'h')) {
client.println("Connnection: close");
client.println();
switch (HTTP_req[7]) {
case '1':
webFile = SD.open("h01.htm");
case 'T':
case '2':
webFile = SD.open("h02.htm");
else if (HTTP_req[9] == 'p') {
case '1':
webFile = SD.open("I01.png");
if (webFile) {
client.println();}
case '2':
webFile = SD.open("I02.png");
if (webFile) {
client.println();}
if (webFile) {
webFile.close();
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
if (c == '\n') {
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++) {
str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
char found = 0;
char index = 0;
char len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
Cependant cela ne marche pas et les caracteres renvoyés ne correspondent pas à mes attentes
Imprimez sur Serial l’ensemble des requêtes que vous recevez (tout le texte de la requête) ça vous permettra de voir ce que le navigateur attend et si votre analyseur est correct
Merci pour ton conseil. J'ai donc placé un serialprint au début de ma boucle et dans le moniteur je vois que l'élément identifier est bien la lettre p mais pour autant cela n'active pas la condition qui lui est liée et donc l'image ne s'affiche pas. Je ne comprends pas pourquoi :
#include <SPI.h>
#include <SD.h>
File webFile;
if (!SD.begin(4)) {
req_index++;
Serial.print(c);
client.println();
case '1':
case 'T':
case '2':
else if (image(HTTP_req[9]) ) {
if (webFile) {
client.println();}
if (webFile) {
webFile.close();
req_index = 0;
if (c == '\n') {
str[i] = 0;
char found = 0;
char index = 0;
char len;
len = strlen(str);
return 0;
found++;
return 1;
else {
found = 0;
index++;
return 0;
char image(char *str)
if (str[9] == 'p') {
return 1;
else {
return 0;}
Merci de ton aide, je vais essayé de rajouter ce code derrière l'envoi de l'image. Cependant je pense que le problème est plus localisé sur le traitement des lettres de la requête car, par exemple ce code fontionne :
#include <SPI.h>
#include <SD.h>
File webFile;
if (!SD.begin(4)) {
req_index++;
Serial.print(c);
|| StrContains(HTTP_req, "GET /h01.htm")) {
client.println();
webFile = SD.open("ho1.htm"); // open web page file
else if (StrContains(HTTP_req, "GET /h02.htm")) {
client.println();
webFile = SD.open("ho2.htm"); // open web page file
else if (StrContains(HTTP_req, "GET /I01.jpg")) {
if (webFile) {
client.println();
if (webFile) {
webFile.close();
req_index = 0;
if (c == '\n') {
str[i] = 0;
char found = 0;
char index = 0;
char len;
len = strlen(str);
return 0;
found++;
return 1;
else {
found = 0;
index++;
return 0;
Bonjour,
Je n'ai pas eu le temps de tout lire car cela me semble un peu compliqué pour quelque chose qui est normalement simple : envoyer une requête GET à un serveur web pour déclencher des actions en fonction de la valeur des paramètres.
Voici un exemple que j'utilise pour une petite application chargée de déclencher un son et de faire clignoter une diode lorsque le serveur web reçoit la requête.
http://adresseIParduino:port?son=2&diode=1 (la requête envoyée avec 2 paramètres)
Côté serveur web dans le sketch .ino, il suffit de réaliser une fonction basée sur l'identification du caractère ? et du caractère & tant que le client est connecté.
//fonction décodage GET
String GET(EthernetClient cl) {
int lecture = 0; // variable pour les étapes de décodage
String donnee = ""; //chaine pour stocker la lecture des données
while (cl.available()) { // tant qu'il a des infos à transmettre
char c = cl.read(); // on lit le caractère
if (lecture == 0 && c == '?') { //début de lecture des données donc d'un nom
lecture = 1;
donnee = "";
else if ((lecture == 1) && c == ' ') { //fin de lecture
lecture = 2;
else if (lecture == 1) {//récupération des données de nom ou de valeur
donnee += c;
delay(1); //delai de lecture
Serial.println(donnee); //pour vérifier dans le moniteur série
// traitement des actions en fonction de la valeur des paramètres
if(donnee.indexOf("son=1") >=0) {
Serial.println("son=1 ok");
son=1;
if(donnee.indexOf("son=2") >=0) {
Serial.println("son=2 ok");
son=2;
if(donnee.indexOf("diode=2") >=0) {
Serial.println("diode=2 ok");
diode=2;
return donnee; // retour de la chaîne de réponse
Merci, pour les réponses apportées, en fait l'erreur était due à une accolade mal placée lors de l'écriture de la condition portée par le caractere 9 stocké dans le buffer. Le programme fonctionne mais le site hébergé doit être très léger peu d'images sinon tout ne charge pas
#include <SPI.h>
#include <SD.h>
int led = 8;
// size of buffer used to capture HTTP requests
File webFile;
String readString;
pinMode(led, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
if (!SD.begin(4)) {
if (!SD.exists("h01.htm")) {
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
digitalWrite(7, HIGH);
digitalWrite(7, LOW);
digitalWrite(6, HIGH);
digitalWrite(6, LOW);
delay(1000);}
readString += c;// save HTTP request character
req_index++;
Serial.print(c);
client.println();
else if ((HTTP_req[9])=='h') {
client.println();
switch (HTTP_req[7]){
case '2' :
case '3' :
webFile = SD.open("h03.htm");
else if (StrContains(HTTP_req, "GET /I01.png")) {
if (webFile) {
client.println("HTTP/1.1 200 OK");}}
else if (StrContains(HTTP_req, "GET /I02.png")) {
if (webFile) {
else if (StrContains(HTTP_req, "GET /I03.png")) {
webFile = SD.open("I03.png");
if (webFile) {
if (webFile) {
webFile.close();
req_index = 0;
if (c == '\n') {
client.stop();
if (readString.indexOf("?l1a") >-1){
if (readString.indexOf("?l1b") >-1){
if (readString.indexOf("?l2a") >-1){
if (readString.indexOf("?l2b") >-1){
//clearing string for next read
readString="";
str[i] = 0;
char found = 0;
char index = 0;
char len;
len = strlen(str);
return 0;
found++;
return 1;
else {
found = 0;
index++;
return 0;}
pb : cela ne fonctionne que si je clique sur les boutons toutes les secondes sinon un message d'erreur apparait : l la connexion a été réinitialisé...
