Ethernet fails with lighttpd server.
I've run the sample WebClient software on Apache and thttpd with excellent success, however when attempting to access a lighttpd daemon, it doesn't work. I brought up the daemon on two different systems and wget, perl curl, Firefox and Opera all like the page just fine. I did a tcpdump on both the lighttpd and thttpd ports. Unfortunately I don't know what I'm looking at.
Once in a great while, it will connect, but normally it just sits there until the connection times out. I get the "connected" message, but apparently no data is forthcoming.
Here's a zip file with the program and the two dumps, if anyone can help me.
http://k4gvo.com/etherprob.zip
Note the program in the zip file has the original port/ip. All I did was change the ip and port numbers to something else.
Thanks, Jim.
Hi
Had the same problem, all other servers i tried did work but not lighttpd. However, got it working by replacing:
client.println("GET / HTTP/1.0"); client.println();
with
client.print("GET / HTTP/1.0\r\n"); client.print("\r\n");
I dont see a big difference in these lines but the second one works...
Great, thanks. I'll keep that in mind. Since I had the option, I trashed lighttpd and install minihttp instead, but I may encounter it again.
Jim.
