Ethernet for Due
Hi All,
I'd like to use ethernet with the Due. As I understand it, the Ethernet Shield won't fit. And even if it did, it uses the SPI pins, which I need for communicating with my device.
I see that there is an EtherDue from Freetronics, which would be perfect, but it is not currently available.
Any workarounds?
Thanks,
David
The ethernet shield works fine with the Due. It fits great. Plugs right in. If you are using a pre-R3 ethernet shield, insure the ICSP pins are aligned, and there will be two sockets on each side that are not used.
megascops:
Hi All,
Any workarounds?
Thanks,
David
We have some EtherDues in stock:
http://tronixlabs.com/arduino/boards/due/freetronics-etherdue-arduino-due-compatible-with-ethernet
