Hi
In my sketch, the first couple of calls to do Ethernet related things work...but then subsequent ones fail. It's a bit odd.
Button One pressed.
2012-03-01 09:38:12 Twitter notified.Button One pressed.
Error : code 403
I find that quite odd.
I get the same result if I take Twitter out of the loop and use a HTTP get request instead. The first one seems to work OK, but then not subsequent ones. Would someone mind taking a look at my code and see if I've done something regrettable?
#include <Twitter.h>
#include <Bounce.h>
#include <Wire.h>
#include "RTClib.h"
#include <Servo.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
byte mac[] = {
0x00, 0x11, 0x22, 0x33, 0xFB, 0x11
EthernetClient client;
Twitter twitter("mytwitterhashpass");
unsigned int localPort = 8888;
byte timeServer[] = {
193, 79, 237, 14}; // ntp1.nl.net NTP server
const int NTP_PACKET_SIZE= 48; // NTP time stamp is in the first 48 bytes of the message
byte pb[NTP_PACKET_SIZE]; // buffer to hold incoming and outgoing packets
#if ARDUINO >= 100
EthernetUDP Udp;
#endif
Servo servo1;
#define ledPin1 8 // the number of the LED pin
#define buttonPin 2 // the number of the button pin
const int pinSpeaker = 7;
boolean EthernetRunning = true;
int buttonState = LOW; // used to set the button state
int LedState1 = LOW; // used to set the LED state
int LedState2 = LOW; // used to set the LED state if LED was already on
long LedOnDuration = 10000; // time to keep the LED on for (10s)
long FlashRate = 400; // time to keep the LED on for (0.4s)
long previousMillis1 = 0; // will store last time LED was updated for press 1
long previousMillis2 = 0; // will store last time LED was updated for press 2
IPAddress server(207,7,108,103);
unsigned int RTCUD = 0;
unsigned int INITIALSET = 0;
// Instantiate a Bounce object with a 20 millisecond debounce time
Bounce nursery = Bounce( buttonPin, 500);
int nurseryvalue;
RTC_DS1307 RTC;
enum {
OFF, ON, FLASH
pinMode(buttonPin,INPUT);
pinMode(ledPin1,OUTPUT);
pinMode(pinSpeaker, OUTPUT);
digitalWrite(ledPin1, OFF);
servo1.attach(6);
LedState1 = OFF;
LedState2 = OFF;
Serial.begin(57600);
Wire.begin();
RTC.begin();
Serial.println("Annunciator Panel v0.7");
Ethernet.begin(mac);
if (Ethernet.begin(mac) == 0)
Serial.println("Error: No DHCP!");
EthernetRunning = false;
if(EthernetRunning)
Udp.begin(localPort);
Serial.println("DHCP is working so enabling UDP.");
if (! RTC.isrunning())
Serial.println("Error!: The RTC is NOT running/set!");
DateTime now = RTC.now();
nursery.update();
nurseryvalue = nursery.read();
char button1msg[162];
sprintf(button1msg, "Doorbell pressed on %d/%d/%d @ %d:%d", now.day(), now.month(), now.year(), now.hour(), now.minute());
char button1msg2[162];
sprintf(button1msg2, "Doorbell pressed again on %d/%d/%d @ %d:%d", now.day(), now.month(), now.year(), now.hour(), now.minute());
if (currentMillis > 20000 && INITIALSET < 1 && EthernetRunning == true)
Serial.println("20s have elapsed since power on/reset.");
Serial.println("A good time to check the clock is running accurately.");
RTCUD = 1;
if (now.minute() == 58 && now.second() == 50 && EthernetRunning == true)
if (RTCUD < 1)
Serial.print("Time to set the clock in time for the pips: ");
RTCUD = 1;
if (RTCUD == 1)
RTCUD = 0; // RTC flag - CAN be set again for the morning / evening
INITIALSET = 1; // RTC has been set at least once this instance
Serial.print("RTC before: ");
PrintDateTime(RTC.now());
sendNTPpacket(timeServer);
if ( Udp.parsePacket() )
Udp.read(pb, NTP_PACKET_SIZE);
unsigned long t1, t2, t3, t4;
t1 = t2 = t3 = t4 = 0;
for (int i=0; i< 4; i++)
t1 = t1 << 8 | pb[16+i];
t2 = t2 << 8 | pb[24+i];
t3 = t3 << 8 | pb[32+i];
t4 = t4 << 8 | pb[40+i];
float f1,f2,f3,f4;
f1 = ((long)pb[20] * 256 + pb[21]) / 65536.0;
f2 = ((long)pb[28] * 256 + pb[29]) / 65536.0;
f3 = ((long)pb[36] * 256 + pb[37]) / 65536.0;
f4 = ((long)pb[44] * 256 + pb[45]) / 65536.0;
const unsigned long seventyYears = 2208988800UL;
t1 -= seventyYears;
t2 -= seventyYears;
t3 -= seventyYears;
t4 -= seventyYears;
t4 += 1;
if (f4 > 0.4) t4++;
RTC.adjust(DateTime(t4));
Serial.print("RTC after : ");
Serial.println("Time update successful");
RTCUD = 0; // RTC has been set for the morning / evening
INITIALSET = 1; // RTC has been set for the morning / evening
Serial.println("Error: UDP Unavailable");
if (nurseryvalue == HIGH)
if (buttonState == OFF)
// button pressed
buttonState = ON;
if (LedState1 == OFF)
// the button's pressed and LED is OFF
// turn it ON
digitalWrite(ledPin1, ON);
LedState1 = ON;
servo1.write(180);
previousMillis1 = currentMillis;
Serial.print("Button One pressed.");
if(EthernetRunning)
if (twitter.post(button1msg))
int status = twitter.wait();
if (status == 200)
Serial.print("Twitter notified.");
Serial.print("Error : code ");
Serial.println(status);
Serial.println("Error: Twitter post failed.");
else if (LedState1 == ON)
LedState1 = FLASH;
servo1.write(180);
Serial.print("Button One pressed again.");
if(EthernetRunning)
if (twitter.post(button1msg2))
if (status == 200)
if (client.connect(server, 80))
//client.println("GET http://www.myserver.org/annunciator/sms.php HTTP/1.0");
client.println();
Serial.println("Sending an SMS.");
Serial.println("Error: Could not notify myserver.org to send that SMS!");
buttonState = OFF;
servo1.write(0);
if (previousMillis1 + LedOnDuration < currentMillis)
LedState1 = OFF;
if (LedState1 == FLASH && previousMillis2 + FlashRate < currentMillis)
digitalWrite(ledPin1, !digitalRead(ledPin1));
previousMillis2 = currentMillis;
void PrintDateTime(DateTime t)
char datestr[24];
sprintf(datestr, "%04d-%02d-%02d %02d:%02d:%02d ", t.year(), t.month(), t.day(), t.hour(), t.minute(), t.second());
Serial.print(datestr);
unsigned long sendNTPpacket(byte *address)
// set all bytes in the buffer to 0
memset(pb, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
pb[0] = 0b11100011; // LI, Version, Mode
pb[1] = 0; // Stratum, or type of clock
pb[2] = 6; // Polling Interval
pb[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
pb[12] = 49;
pb[13] = 0x4E;
pb[14] = 49;
pb[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
#if ARDUINO < 100
Udp.sendPacket( pb,NTP_PACKET_SIZE, address, 123); //NTP requests are to port 123
#else
// IDE 1.0 compatible:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(pb,NTP_PACKET_SIZE);
Udp.endPacket();
#endif
