Ethernet in muti-task or in piece
With arduino mega 2560 + ethernet shield + arduino 0022 + standard library (#include <SD.h>, #include <Client.h>, #include <Ethernet.h>, #include <Server.h>, #include <Udp.h>, #include <SPI.h>)
I have make this sketch (symbolic)(real code take ~2000 lines):
LOOP
  • every 200ms -> read bouton + say launch task
  • if task 1 : do task 1 part 1 (if end next step part 2) or task 1 part 2 (ect...) or ....
  • if task 2 : ......
  • if ....
  • if ethernet do task ethernet : send a file on SD
    END LOOP
It's work but i must have each loop time less time than 200ms or not so far away. So as your see, i have cut every task on pieces, but ethernet was in one piece and if i ask for big file (10ko!!) on SD cart, it take 2-5 second, it's too big, i must have to make other task in //, i try to make ethernet in piece but compilator always say error like :
error: 'client' was not declared in this scope
when I try to compile this (symbolic) :
LOOP
  • if ....
  • if "!ethernet" do find client connection (if client ask 'client read' on next loop)
  • if "client read" do read 1 byte and analyse data (if header end 'header end' on next loop)
  • if "header end" do read and send 1 line of file (if file all send 'end of client' on next loop)
  • if "end of client" do end of client and validate '!ethernet' on next loop
    END LOOP
How can i do if it's possible ?
Well, now, we really need to see some code. We can't tell where you defined client, or where you are trying to reference it, without seeing ANY code.
Here is the code (in loop) :
	if(!exec&0x80) {  // un client connecter
		Client client=server.available();
		if(client) {  // on a une connection demande
			exec|=0x80;
			exec_8=0;
			b_ligne=1;
			ethbid=0;
			ethcid=0;
			digitalWrite(11,HIGH);  // debug
	if(exec&0x80) {  // attente client
		if(exec_8==0) {  // lecture requete
			if(client.connected()) {        <<ERROR
				if(client.available()) {
					if(eth_head(client.read())==1) {   << analyse and buffer read data
			else exec_8=20;
		if(exec_8==20) {  // if client
			delay(1);
			client.stop();     << ERROR
			digitalWrite(11,LOW);  // debug
			exec&=0x7f;
It's not finish because i have stopped after further try : declare Client, arrange the code in different way... nothing can be compile...
You are declaring your client within your first if() statement. It'll only exist for the life of that statement, so any access outside that statement is invalid. You must declare it somewhere that remains in scope for the entire time it is being used.
Yes, it was difficult to find how to declare client, but i find :
"Client client(4);" out of loop declare a global Client class for server mode, and it work fine : ie you can use client every where in the sketch, i can run my 200ms staff and cut the ethernet request even if the ethernet task have 5s time run.
Note : the line "Client client=server.available();" become "client=server.available();" in the code.
Resolved.
