Ethernet/Modbus communication issue with Portenta Machine Control(PMC)
Hi Guys,
I am trying to send data from my local PC to my PMC with Modbus TCP protocol, but I am not able establish communication MOST of the times. I was able to establish communication and send data certain times, but the next time when I try to reload the same code , I am not able to communicate between PMC and PC.
Here are the following code snippets(NOTE: I use a LInux VM as my OS).
  • Python server
from pyModbusTCP.server import ModbusServer, DataBank
from socket import *
host = '192.168.1.170'
port = 1500
class mydatabank(DataBank):
    def __init__(self):
        super().__init__()
    def get_holding_registers(self, address,number  = 1):
        self._h_regs[0] = 0
        self._h_regs[1] = 1
        #repcakage data into a list
        try:
            return[self._h_regs[i] for i in range(address,address + number)]
        except KeyError:
            return
if __name__ == '__main__':
    server = ModbusServer(host=host, port=port, data_bank=mydatabank())
    server.start()
  • Arduino Client
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoRS485.h>
#include <ArduinoModbus.h>
#include <Arduino_MachineControl.h>
using namespace machinecontrol;
EthernetClient ethClient;
ModbusTCPClient modbusTCPClient(ethClient);
byte mac[] = {
  0x90, 0xA2, 0xDA, 0xF8, 0x5A, 0xF3
IPAddress ip(192, 168, 1, 11);
IPAddress server(192,168,1,170);
  while(!Serial)
  Ethernet.begin(mac, ip);
  Serial.print("My IP is ");
  Serial.println(Ethernet.localIP());
  int f = modbusTCPClient.begin("192.168.1.170", 1500);
  Serial.println(f);
   // int f = modbusTCPClient.begin("192.168.1.170", 100);
   // Serial.println(f);
      // digital_outputs.set(4, modbusTCPClient.holdingRegisterRead(0));
      // delay(2000);
      // digital_outputs.set(4, modbusTCPClient.holdingRegisterRead(1));
  int value = modbusTCPClient.holdingRegisterRead(1);
   Serial.println(value);
I am totally new to this Protocol. So Any help regarding solving this would be greatly appreciated!
Best Regards,
H_SE
Post a simple schematic showing how each of the units is interconnected. Be sure to show any external hardware. Also how is it powered.
Network adapter settings in the VM(namely Virtualbox) is set to 'Bridged adapter'. The ethernet ports of the PMC and PC and connected directly with a Ethernet Cross-over cable.
