Ethernet module + RFID reader - Pin interfearence?
Hi guys!
I'm fairly new to this Arduino-stuff, so this might sound dumb in your expirenced ears.
Currently I'm setting up a project, that alows me to see the UID of a scanned RFID card via ethernet.
But then i ran into some problems...
The parts for this project is currently;
1x Arduino Uno
1x MFRC-522 RFID reader/writer
1x Ethernet ENC28J60 module
I have tried to setup the RFID scanner and the ethernet module indipendent, and her comes the problem.
The scanner is wire like this:
RST/Reset = pin 9
SPI SS = pin 10
SPI MOSI = pin 11
SPI MISO = pin 12
SPI SCK = pin 13
And all of that works like a charm.
Then i wanted to wire the ethernet module, but it uses some of the same pins.
The ethernetmodule is using the following:
SCK - Pin 13
SO - Pin 12
SI - Pin 11
CS - Pin 10
Im using these librarys:
RFID = GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522
Ethernet: GitHub - njh/EtherCard: EtherCard is an IPv4 driver for the ENC28J60 chip, compatible with Arduino IDE
Is there a way i can make this work?
Thank you SO MUCH!
Best regards,
Frederik, Denmark :wink:
I'm doing this as same as U.Each one goes well when separated,but only the RFID part work when they get together even if I did turn CS pins high and low.Have done that?have u solve this problem?what's wrong.........
Hope for your reply.......
p.s. I'm chinese, so i may using wrong grammer
