Hello,
I’m currently working on a project to send data to a MQTT using Ethernet with an MKRZero board and a MKR ETH Shield.
I am trying to make a first communication using the example from the Arduino IDE. Here is the code used to make first tests :
// This example uses an Arduino Uno together with
// an Ethernet Shield to connect to shiftr.io.
// You can check on your device after a successful
// connection here: https://www.shiftr.io/try.
// by Joël Gähwiler
// https://github.com/256dpi/arduino-mqtt
#include <Ethernet.h>
#include <MQTT.h>
byte mac = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte ip = {192, 168, 137, 177};
EthernetClient net;
MQTTClient client;
unsigned long lastMillis = 0;
void connect() {
Serial.print(“connecting…”);
while (!client.connect(“arduino”, “public”, “public”)) {
Serial.print(".");
Serial.println("\nconnected!");
client.subscribe("/hello");
// client.unsubscribe("/hello");
void messageReceived(String &topic, String &payload) {
Serial.println("incoming: " + topic + " - " + payload);
// Note: Do not use the client in the callback to publish, subscribe or
// unsubscribe as it may cause deadlocks when other things arrive while
// sending and receiving acknowledgments. Instead, change a global variable,
// or push to a queue and handle it in the loop after calling client.loop()
Ethernet.begin(mac, ip);
// Note: Local domain names (e.g. “Computer.local” on OSX) are not supported
// by Arduino. You need to set the IP address directly.
client.begin(“public.cloud.shiftr.io”, net);
client.onMessage(messageReceived);
connect();
client.loop();
if (!client.connected()) {
connect();
// publish a message roughly every second.
if (millis() - lastMillis > 1000) {
lastMillis = millis();
client.publish("/hello", “world”);
I have downloaded all the libraries and previous tests shows that the ethernet communication is working. But when it comes to connecting to the client, it’s not working and printing “.” constently on the Serial monitor (as intended in the code in case of no connection)
For information in the Network and Sharing Center, my Ethernet port IPV4 is set to 192.168.137.1.
The code is trying to connect to the MQTT “public.cloud.shiftr.io” but it is not working. I tried with several other free online MQTT but none seems to be working.
I tried looking for answers on the forum but most posts concern WIFI and not Ethernet, and trying to adapt possible solutions didn’t work.
That’s why I’m posting this to see if someone can see a problem on the code or has an idea on how to correct my problems.
I’m also wondering if you have a specific MQTT to recommend. I tried several but I don’t know which one is the best to test. Maybe my problems come from this.
