i'm using standard EthernetShield on multiple arduino boards (diecimila, duemilanove with atmega328, uno, mega 2560) and experiencing strange problem.
Example WebServer script works without problems, dhcp works, i can ping arduino but Web Client examples only works in local network, i don't get any response from servers outside it.
Tried all of the arduinos, tried connecting without router but nothing seems to help. Arduino get's ip from dhcp (tried manualy specifying ip, dns, gateway, netmask), makes request, but that's all).
Simple client test code you can try.
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
client.println("Host: web.comporium.net");
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
@billroy
code was example from ethernet library, unmodifided.
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
modified 9 Apr 2012
by David A. Mellis
#include <SPI.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
IPAddress server(173,194,33,104); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
for(;;)
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.0");
client.println();
else {
// kf you didn't get a connection to the server:
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
client.stop();
// do nothing forevermore:
for(;;)
Still smells like a gateway configuration issue. A quick test might be to explicitly initialize the gateway using the "Ethernet.begin(mac, ip, dns, gateway); " form of the ethernet.begin call.
Your earlier post about capturing the network traffic is a good next step. WireShark isn't too hard to set up if you have a PC on that network segment.
maptnh: @billroy
You said unmodified, but you do realise you have to modify this part to set your device MAC address?
The other thing is, might you have your router set for security where you need to specify allowed MAC addresses?
Client test code that allows for specifying ip addresses.
//zoomkat 4-04-12
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
//the arduino lan IP address { 192, 168, 1, 102 } may need
//to be modified modified to work with your router.
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 }; // ip in lan assigned to arduino
//byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
//byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte myserver[] = { 208, 104, 2, 86 }; // zoomkat web page server IP address
void setup(){
Ethernet.begin(mac, ip);
//Ethernet.begin(mac, ip, gateway, gateway, subnet);
Serial.println("Better client test 4/04/12"); // so I can keep track of what is loaded
void loop(){
if (client.connect(myserver, 80)) { //starts client connection, checks for connection
else {
