Solved
In the moment I press that button I want to send a message on my android device.
What have you tried that didn't work?
solved
Bump
No one ![]()
Buttons need to be debounced and change of state detection to prevent issues. The below client test code might be useful in initial testing of the notification using PushingBox API.
//zoomkat 3-1-13
//simple client checkip test
//for use with IDE 1.0.1 or later
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // test web page server
EthernetClient client;
void setup(){
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
Serial.println("Better client ip test 3/1/13"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET / HTTP/1.0"); //download text
client.println("Host: checkip.dyndns.com");
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
First of all I wanna thank you for your reply I really appreciate it. I couldn't reply the first two days cause I was caught up in work over the weekend. I've tried yesterday and today but I can't exactly comprehend what to do next.
I have tested your code and it is working. I mean when I pressed e in serial monitor it's connecting to the internet. Can you explain to me a little you have time what's to do? Sorry and much thanks in the same time.
