Hey guys,
it turns out that the Ethrenet-Shield I use (official Arduino Ethernet shield) seems to work fine as long as I attempt to connect to it one time. With one connection it runs totally fine, but wen the connection gets lost, the Ethernet shield doesn`t realize the connection is gone.
Now I have a two questions:
Is there
a way to make sure the ethernet shield understands a connection got lost ? At the moment it just sends and receives data to another device which is not listening/sending any more, which is a deadlock, because I cannot reconnect and replace the current connection
any smart Approach how to deal with the situation? What is the common way? My next approach would be to implement a heartbeat and check via that if there is still a listener on the other side. In case several heartbeats don`t get throught, I know the connection is lost and I disconnect on the Ethernet-Shield, waiting for a new connection. Would that be a common solution?
So this is sort of a heartbeat implementation by checking if there is still any data transmitted.
that might work fine for me, but doesn`t feel like a 'nice' solution from an IT point of view.
But it should work.
Anyway, I`d like to find out if there is another solution to realize lost Connection via the 'Client.connected()'. function.
No, client.connected() does not detect a stalled server or broken connection. The client.connected() call will only return false if the connection is closed by a "close" packet. If the server is stalled or the connection breaks, you will never receive that 'close' packet.
I'm trying to make my Arduino to reconnect to host if connection is lost. I don't want to use delay, trying to use millis() instead with 5 seconds of delay. For some reason it works weird: if host is unavailable, I'm getting message to serial "host unavailable" every 5 seconds as i wanted for about 10 times, and then something happens and it looks like Arduino sends this message with no delay, and when I turn on host back it doesn't reconnect, still sending message in endless loop.
Any idea why it happens?
Here is my code:
#include <SPI.h>
#include <Ethernet.h>
bool clientFbConnected = false;
bool setFbReconnect = false;
int timeFbReconnect = 0;
int ReconnectDelay = 5000;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 200);
IPAddress myDns(192,168,1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
EthernetClient clientFb;
IPAddress LegrandIp(192, 168, 1, 222);
// connecting to a gateway
void getFbConnection(){
// setting timer
if(!setFbReconnect){
setFbReconnect = true;
timeFbReconnect = millis();
return;
// checking if timer expired
if(setFbReconnect && ((millis()-timeFbReconnect)>ReconnectDelay)){
// try to connect, report to serial
if (clientFb.connect(LegrandIp, 20000)) {
Serial.println("Feedback connected");
// if you didn't get a connection to the server:
Serial.println("Feedback connection failed");
// receiving bytes from Receive connection
void receiveData(){
if (clientFb.available() > 0) {
// read the bytes incoming from the client:
char thisChar = clientFb.read();
Serial.write(thisChar);
// initialize the ethernet device
Ethernet.begin(mac, ip, myDns, gateway, subnet);
if (clientFb.connected())
receiveData();
getFbConnection();
