Ethernet Sd and Pro Mini
Hey all,
Currently I have set up the Arduino pro Mini (3v) and the Ethernet SD shield and running the SDFatInfo code with a software reset for the Ethernet. I have been playing around with some different code and different settings trying to get it to work. Any body know why/what is going on.
Current setup:
Pin 9 digital reset pin
Pin 10's connected
Pin 4's connected
pinMode(WIZNET_RESET_PIN, OUTPUT);
digitalWrite(WIZNET_RESET_PIN, HIGH);
delay(50);
digitalWrite(WIZNET_RESET_PIN, LOW);
delay(50);
delay(100);
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
  digitalWrite(10, HIGH); // but turn off the W5100 chip!
[code]uint8_t r = card.init(SPI_HALF_SPEED, 4); // Use digital 4 as the SD SS line
Is there a problem with the Pro mini clock speed and the Ethernet shield ...
Serial output I recive
type any character to start
card.init failed
SD error
errorCode: 1
errorData: 0
Thanks all[/code]
Did you connect the SPI pins: 11, 12, and 13?
Is that the Arduino Mega compatible board that runs the SPI signals through the ICSP header?
I did not conect the pins to the icsp header but I did connect pins 11,12,13 together. And yes that is the board I am using.
KMPDigital:
I think the SPI pins of the Ethernet and SD slot connect only through the ICSP pins (to keep the Mega's 11-13 free for other uses). Try connecting there. You'll have to look up the ICSP pinout.
cool I will try it later... after i order a new one :-/ i just shorted my board and fried it... go me :blush: might as well order an Uno while im at it huh...
