I have a test fan (small 5v, I don’t have an led…) linked to gnd and pin 7. I just want a very simple test for this. Can someone help me? I would just like to send on/off commands and perhaps read sensors in the future.
//zoomkat 1-10-11
//web LED code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84/ when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(4, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("servertest1"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c); //uncomment to see in serial monitor
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString);
//now output HTML data header
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>HTML form GET example</H1>");
client.println("<FORM ACTION=\"http://192.168.1.102:84\" method=get >");
client.println("Pin 4 \"on\" or \"off\": <INPUT TYPE=TEXT NAME=\"LED\" VALUE=\"\" SIZE=\"25\" MAXLENGTH=\"50\">
client.println("<INPUT TYPE=SUBMIT NAME=\"submit\" VALUE=\"Change Pin 4!\">");
client.println("</FORM>");
client.println("
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
if(readString.indexOf("on") >0)//checks for on
digitalWrite(4, HIGH); // set pin 4 high
Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
digitalWrite(4, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
