Ethernet Shield Access Problem
Hi everyone..
I am working on the ethernet shield project. I want to check some values from the one device and want to check my computer .. Anyway When I run the uno+ ethernet shield it works fine and I can check values on the explorer. After 30 minute - 1 hour I can't reach the ethernet shield ip on explorer(Err_Timed_out) but I can ping the ethernet shield. When I unplug ethernet shield power and plug again it starts work again.
In addition to If I plug uno + ethernet shield to the switch in my office , it works very long time (I tested 2 days). I think problem is wireless antennas but another device working well same place :confused:
My connection diagram is here:
My codes is here :
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x00, 0x90, 0xE8, 0x5C, 0x43, 0x55 };   //physical mac address
IPAddress ip(10, 8, 0, 20);
IPAddress gateway(10, 8, 0, 1);
IPAddress subnet(255, 255, 255, 0);
EthernetServer server(80);
  Ethernet.begin(mac, ip, gateway, subnet);
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
  server.begin();
  int sensorValue1 = analogRead(A1);
  int sensorValue3 = analogRead(A3);
  int sensorValue5 = analogRead(A5);
  if (client) {
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println(F("HTTP/1.1 200 OK"));
          client.println(F("Content-Type: text/html"));
          client.println(F("Connection: close"));
          client.println(F("Refresh: 5"));
          client.println(F());
          client.println(F("<!DOCTYPE HTML>"));
          client.println(F("<html>"));
          if (sensorValue1 > 260) {
            client.print(F("NORMAL"));
            client.println(F("
          if (sensorValue3 > 260) {
            client.print(F("WARNING"));
            client.println(F("
          if (sensorValue5 > 260) {
            client.print(F("ALARM"));
            client.println(F("
          if ((sensorValue1 < 260) == (sensorValue3 < 260) == (sensorValue5 < 260))  {
            client.print(F("UNKNOWN"));
            client.println(F("
          client.println(F("</html>"));
        if (c == '\n') {
        } else if (c != '\r') {
          currentLineIsBlank = false;
    delay(150);
    client.stop();
P.s.: I changed uno , ethernet shield , and power adaptor .Problem still Continues.
P.S2 : Sorry my English
P.S.3 : I am usin W5100 ethernet shield and I changed 511 resistor with two 100 ohm resistors.
Post pictures to this forum. Images on temporary web storage is treated as not existing.
Antennas alone don't help so there must be some devices involved. For me it sounds like a network problem completely unrelated to Arduino but you may provide additional information that draws another picture.
