Ethernet Shield and MySQL
I'm using the official Ethernet Shield to insert rows into a MySQL table every 5 or 10 sec. I've been successful by modifying one of the ClientConnect example in the Ethernet Library to connect to a php script with the variables in the URL. The PHP parses the variables and handles the MySQL insertion.
Is there a cleaner/faster way to get the job done by connecting directly to the MySQL server?
I'm using the arudino to insert data into a MySQL table as well, but I too am going through a PHP script. I do it because it acts as a security layer for my db. Mysql databases are normally set up to work with a local IP. You can make the MYSQL DB accept different IPs as well. But if you move (eg. your computer is a laptop) or have dynamic IPs or other people use your product to write to your server, you will have to keep adding IPs to the MySQL DB.
hey guys
That's exactly what I want to do, write to a MYSQL DB.
Different Arduinos with Sensors should write theire data
to an DB...
Can someone explain me how to set this up? Or give me
some tips?
Thx in advanced
Geko
coffeeguru: Could you post the code that you are using to call your PHP page? I'm interested in doing something similar to this, but I only want to update the data in my MySQL DB when a switch is pressed. I would eventually like to display a response from the PHP on an LCD on the Arduino as well.
