Ethernet shield and receiver problem
Hi. i need some help about ethernet shield and receiver. I use 2xArduino uno, trassmitter, reciever, sensor BMP080, sensor DHT11 and LCD dispslay with I^2C interface. I take the information from transmitter and want to record it in mysql database.
This is my transsmitter code:
#include <VirtualWire.h>
  #include "LowPower.h"
  #include "DHT.h"
  #include "Adafruit_BMP085.h"
  #include "Wire.h"
  #define DHTPIN 8     // what pin we're connected to
  #define DHTTYPE DHT11   // DHT 11
  DHT dht(DHTPIN, DHTTYPE);
  Adafruit_BMP085 bmp;
  int ledPin = 13;
  char Msg[30];// The string that we are going to send trought rf transmitter
    dht.begin();  // initialing the DHT sensor
    bmp.begin();
    pinMode(ledPin,OUTPUT);
    // VirtualWire setup
    vw_setup(2000); // Bits per sec
    vw_set_tx_pin(12);// Set the Tx pin. Default is 12
      Serial.print("Pressure = ");
      Serial.println(bmp.readPressure());
       Serial.print("Temperature = ");
       Serial.println(bmp.readTemperature());
       Serial.print("Humidity = ");
       Serial.println(dht.readHumidity());
    // Read and store Sensor Data
    int humidity = dht.readHumidity();
    int temp = bmp.readTemperature();
    unsigned long pressure = bmp.readPressure()/100;
     Serial.println(pressure );
    sprintf(Msg, "%d,%d,%d", humidity,temp ,pressure);
   // Turn on a light to show transmitting
    digitalWrite(ledPin, HIGH);
   //LowPower.powerDown(SLEEP_250MS, ADC_OFF, BOD_OFF);
    delay(100);
    vw_send((uint8_t *)Msg, strlen(Msg));
    vw_wait_tx(); // Wait until the whole message is gone
   // Turn off a light after transmission
    digitalWrite(ledPin, LOW);
    // put 5 mins sleep mode
    // As lowpower library support maximam 8s ,we use for loop to take longer (5mins) sleep
    // 5x60=300
    //300/4=75
    for(int i=0;i<75;i++)
    LowPower.powerDown(SLEEP_4S, ADC_OFF, BOD_OFF);    // Instead of delay(4000);
   //delay(4000);
reciever code:
  #include <Wire.h> // use Wire library for protocol i2c (A4 = SDA & A5 = SCL)
  #include <LiquidCrystal_I2C.h> // use LiquidCrystal_I2C library for control LCD on i2c protocol
  #include <VirtualWire.h> // use Virtual library for decode signal from Rx module
  #include <SPI.h>
  #include <Ethernet.h>
  EthernetClient client;
  byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
  char server[] = "192.168.0.101";
  LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); //change the address as per your I2C module
  int humidity=100;
  int temp=200;
  unsigned long pressure=0;
  char MsgReceived[21];
  int led = 13; //pin for LED
  byte thermometer[8] = //icon for thermometer
    B00100,
    B01010,
    B01010,
    B01110,
    B01110,
    B11111,
    B11111,
    B01110
  byte droplet[8] = //icon for droplet
    B00100,
    B00100,
    B01010,
    B01010,
    B10001,
    B10001,
    B10001,
    B01110,
  byte hi[8]=    //icon for heat index
    0B00000,
    0B00000,
    0B10101,
    0B01110,
    0B11111,
    0B01110,
    0B10101,
    0B00000,
    Ethernet.begin(mac);
    lcd.begin(20,4); // set up the LCD's number of columns and rows:
    lcd.backlight(); //backlight is now ON
    pinMode(led, OUTPUT);
//    // VirtualWire
//    // Bits per sec
    vw_setup(2000);
    // set pin for connect receiver module
    vw_set_rx_pin(11);
    // Start the receiver PLL running
    vw_rx_start();
    lcd.begin(20,4);   // initialize the lcd for 20 chars 4 lines, turn on backlight
    lcd.backlight(); // finish with backlight on
    lcd.createChar(1, thermometer);
    lcd.createChar(2, droplet);
    lcd.createChar(3, hi);
    lcd.clear(); // clear the screen
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    //Taking the data from the control base
    if (vw_get_message(buf, &buflen))
      digitalWrite(led, HIGH);
      delay(100);
      int i;
      // Message with a good checksum received, dump it.
      for (i = 0; i < buflen; i++)
        // Fill Msg Char array with corresponding
        // chars from buffer.
        MsgReceived[i] = char(buf[i]);
        Serial.print(MsgReceived[i]);
    connection();
    sscanf(MsgReceived, "%d,%d,%d",&humidity, &temp, &pressure); // Converts a string to an array
    digitalWrite(led, LOW);
    lcd_display();
    memset( MsgReceived, 0, sizeof(MsgReceived));// This line is for reset the StringReceived
    Serial.print(temp);
    Serial.println(" *C");
    Serial.print(pressure);
    Serial.println(" Pa");
    Serial.print("humidity = ");
    Serial.print(humidity);
    Serial.println(" %");
    delay(10000);
  void connection()
    if(client.connect(server, 80)) {
      client.print( "GET /diplomna/Arduino/add_data.php?");
      client.print("temperature=");
      client.print( temp );
      client.print("&&");
      client.print("humidity=");
      client.print( humidity );
      client.print("&&");
      client.print("pressure=");
      client.println( pressure );
      client.println( "HTTP/1.1");
      client.println( "Connection: close" );
      client.stop();
      Serial.println("CONNECTED");
    else {
      // you didn’t get a connection to the server:
      Serial.println("-> connection failed");
  void lcd_display()
  { lcd.setCursor(1,0);
    lcd.print(" WEATHER STATION ");
    lcd.setCursor(4,1);
    lcd.print("TEMP");
    lcd.setCursor(9, 1);
    lcd.write(1);
    lcd.setCursor(11, 1);
    lcd.print(temp);
    lcd.write(0b11011111);
    lcd.print("C");
    lcd.setCursor(4,2);
    lcd.print("HUM");
    lcd.setCursor(9, 2);
    lcd.write(2);
    lcd.setCursor(11, 2);
    lcd.print(humidity);
    lcd.print("%");
    lcd.setCursor(4,3);
    lcd.print("PRS");
    lcd.setCursor(9, 3);
    lcd.write(3);
    lcd.setCursor(11, 3);
    lcd.print(pressure);
    lcd.print("Pa");
receiver serial monitor output:
→ connection failed
Humidity = 73%
tempreture = 23 *C
pressure = 1101 hPa
if i don’t use Rf receiver i can connect to database and make a record (i remove #include <VirtualWire.h> and all rf function) . My display works properly in both cases.
I think that I have a conflict between the receiver and the shield. Can you help me :?
Thanks in advance :slight_smile:
I think you have a pin conflict. SPI uses pins 10,11,12,13 and VirtualWire uses 11. You will have to change that with vw_set_rx_pin(pin).
i change vw_set_rx_pin(5), but connecation failed again :frowning:
One more change - the function connection() is out of the is statement:
     delay(100);
     int i;
   connection();
The first argument to the connect() method is either a string that is a server name, OR an IP address as 4 bytes. It is NOT an IP address as a string.
Don't use D13 for the LED. That is the SPI clock pin on the Uno.
I removed the LED and changed ip address: byte server = { 192, 168, 0, 101 }; and still doesn't work :frowning:
Add some debug stuff. Start with this in the receiver code.
// replace this
// with this
    while(!Ethernet.begin(mac)) {
      Serial.println("DHCP failed. Try again in 5 seconds");
      delay(5000);
    Serial.println(Ethernet.localIP());
Does it get an IP?
Can you connect to the server with a PC on the localnet? Don't use the server for this test. Try from a separate PC.
I replace the code, but i can't get ip.
when i tried to connect to the server with other pc, this is the message:
Access forbidden!
New XAMPP security concept:
Access to the requested object is only available from the local network.
This setting can be configured in the file "httpd-xampp.conf".
Then you have two problems.
  1. You are not getting an IP.
  2. The server will not let you connect.
I can’t understand, why when I use this code below, everything works fine, but when added receiver and its functions i can’t connect to database. I think there is a conflict between the shield and receiver, but I can’t understand where exactly the things go wrong:
this is the code that make records in database:
 #include <SPI.h>
 int interval = 5000; // Wait between dumps
   B00100,
   B01010,
   B01010,
   B01110,
   B01110,
   B11111,
   B11111,
   B01110
   B00100,
   B00100,
   B01010,
   B01010,
   B10001,
   B10001,
   B10001,
   B01110,
   0B00000,
   0B00000,
   0B10101,
   0B01110,
   0B11111,
   0B01110,
   0B10101,
   0B00000,
 };                 //(addr, EN,RW,RS,D4,D5,D6,D7,BL,BLpol)
 // Sensors
 int humidity=0;
 int temp=0;
 int pressure=0;
 } // END void setup
   if (client.connect(server, 80)) {
   client.print("temperature=");;
   client.print( temp);
   client.print("&&");
   client.println( humidity );
   client.stop();
 else {
   Serial.println("–> connection failed/n");
 lcd_display();
 delay(interval);
 void lcd_display()
   lcd.setCursor(4,1);
   lcd.print("TEMP");
   lcd.write(1);
   lcd.print(temp);
   lcd.print("C");
   lcd.setCursor(4,2);
   lcd.print("HUM");
   lcd.write(2);
   lcd.print("%");
   lcd.setCursor(4,3);
   lcd.print("PRS");
   lcd.write(3);
   lcd.print("Pa");
Serial monitor:
  • CONNECTED
  • CONNECTED
  • CONNECTED
I don't see where it is working fine.
You are not reading and displaying the response from the server.
You are calling the client.stop function before you get a response from the server.
The shield won't get an IP using dhcp.
What part of that do you see as working fine?
Make these changes and try it again.
// add this line here
   client.print("&&");
// change this to a print rather than println
// add a leading space in this println
   client.println( " HTTP/1.1");
// add a second cr/lf here to denote end of header
   client.println( "Connection: close\r\n" );
// add this
   while(client.connected()) {
      while(client.available()) {
        char ch = client.read();
        Serial.write(ch);
// end of add
   client.stop();
   Serial.println("DISCONNECTED");
 else {
   // you didn't get a connection to the server:
   Serial.println("-> connection failed/n");
edit: Corrected a bunch of errors in you request send. Look for comments.
When I use this code, the arduino takes the values for humidity and temperature and makes records in MySQL database. Thats all i want.
When i use your code:
     delay(5000);
in the second case, i get the ip. Everything working fine.
When i replace your code in second case, this is the output:
192.168.0.102
CONNECTED
HTTP/1.1 400 Bad Request
Date: Wed, 03 Jun 2015 14:29:32 GMT
Server: Apache/2.4.10 (Win32) OpenSSL/1.0.1i PHP/5.5.15
Vary: accept-language,accept-charset
Accept-Ranges: bytes
Connection: close
Content-Type: text/html; charset=utf-8
Content-Language: en
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
  "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
<head>
<title>Bad request!</title>
<link rev="made" href="mailto:postmaster@localhost" />
<style type="text/css"><!--/*--><![CDATA[/*><!--*/
    body { color: #000000; background-color: #FFFFFF; }
    a:link { color: #0000CC; }
    p, address {margin-left: 3em;}
    span {font-size: smaller;}
/*]]>*/--></style>
</head>
<body>
<h1>Bad request!</h1>
<p>
    Your browser (or proxy) sent a request that
    this server could not understand.
</p>
<p>
If you think this is a server error, please contact
the <a href="mailto:postmaster@localhost">webmaster</a>.
</p>
<h2>Error 400</h2>
<address>
  <a href="/">localhost</a>
  <span>Apache/2.4.10 (Win32) OpenSSL/1.0.1i PHP/5.5.15</span>
</address>
</body>
</html>
DISCONNECTED
This is ouput, when i use RF receiver + your code:
→ connection failed/n
Temperature = 200 *C
Pressure = 0 Pa
This reply will be caused by any of the errors I corrected above in reply#10.
Insure you correct them all.
