Ethernet shield and several connections (one after another) problem
Hey guys, I do have the following problem:
I use an arduino and the ethernet shield for Connections through the Network (later, it should work through the internet). On the Arduino there is a Server running and the class I use is the "EthernetServer class.
I can easily connect to the device via port 23 by a c# Programm that uses TCPClient and all works fine, until I would like to find out if a connection got lost and until I want to connect a second time.
A first connect always works, but a second, third or fourth attemp never works. After a reboot of the arduino it works only for one connection again.
So I have the following questions:
  • How can I find out if a Connection got lost?
  • How to reset the Server then, to make sure I can do a reconnect by a Client?
Does anyone have a Code example which describes how a sever should get implemented to accept several connections?
What I do not Need to get are muliple Connections at the same time. I am only interested in one Connection after another...
The Ethernet library documentation didn`t help me or I missed something.
Best J_witt
OK, solved!
Client.available() Needs to be used like this:
    if (client)
        while (client.connected())
            if (client.available())
                char c = client.read();
        delay(100);
        client.stop();
        client = NULL;
Then it works as expected!
Hi bro can you give me your complete code?
