Ethernet shield and solder bridges
Hi all,
I received a W5100-based Ethernet shield from an eBay seller today and while inspecting it I noticed a number of solder bridges between pins on the W5100 itself:
  1. Possible solder bridge 9-10
    http://i681.photobucket.com/albums/vv178/grue2/Computers/pict10832.jpg
  2. Solder bridges 22-23, 24-25, 36-37, 38-39
    http://i681.photobucket.com/albums/vv178/grue2/Computers/pict10842.jpg
  3. Solder bridges 41-42, 47-48, 49-50, 51-52
    http://i681.photobucket.com/albums/vv178/grue2/Computers/pict10852.jpg
Checking against the schematic at http://arduino.cc/en/uploads/Main/arduino-ethernet-shield-06-schematic.pdf I'm not too concerned about most of the bridges (22-23, 24-25, 36-37, 38-39, 41-42, 47-48, 49-50 and 51-52) as they are all joined to GND. The bridge on pins 9-10 concerns me, though, as that would cause TX-/R4 to be pulled to GND when it shouldn't be.
I don't have a multimeter available at the moment to double-check (it's loaned out). Is it likely to cause any damage to the Arduino board if I plug it in?
I'd remove it before connecting the thing to an Arduino. Looks like you got a really low quality shield...
Could be worth contacting the vendor and sending (or linking) those photos. Usually eBay sellers are keen to protect their reputation.
Thanks. I've messaged the seller with links to the photos and asked if they want me to send the unit back. Time will tell...
