Ethernet Shield + BMP085 pressure sensor
Hello everyone,
I tried to use ethernet shield as a webserver acquiring data from BMP085 and then posting it to a html page that I call on browser with ethernet shield IP adress. Should be pretty simple but the measurements from sensor do not make sense when I use the code below. Instead of getting pressure like 101285 it shows 959 or something like that…
If I only use the BMP085 library and write the data on the serial com, the values showed are correct.
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 15);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
Adafruit_BMP085 bmp;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
   Serial.print(bmp.readTemperature());
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          client.print("Temperature = ");
          client.print(bmp.readTemperature());
          client.println("
          Serial.println(bmp.readTemperature());
          client.print("Pressure = ");
          client.println("
          client.print(bmp.readPressure());
          Serial.print(bmp.readPressure());
          client.println(" Pa");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
Cheers,
