Ethernet shield Cannot connect my pc if use HUB 5 port
hi my name is riza, Iam from Indonesia. I have a problem with arduino + ethernet shield in my project. when i connect my laptop to the ethernet directly using a straight cable I can connect with ethernet. but if I use HUB 5port I can not connect. if I ping (destination host unreachable) please help. thank you
How is that an Arduino problem?
Have a look at this thread .... http://forum.arduino.cc/index.php?topic=351477.0
I had a problem using an 8 port SWITCH.
However when I changed to an 8 port HUB it worked fine.
It seems that most modern devices are Switches (as against Hubs)
I was fortunate that I have on old Intel Hub.
Also, it seems that some cheap Ethernet shields (like the HanRun ones I use) have a wrong resistor fitted and this changes the impedence that will be seen by the Switch or Hub.
Bruce
