ethernet shield can't send data [+PN532]
i use PN532 + ethernet shield with arduino UNO
first, i change some ethernet shield web client example code to make loop send some data and get some data back
it’s don’t have a problem
this is my code
#include <SPI.h>
#include <Ethernet.h>
String mxx="data" ;                                                       //mydata
int LED = 8;
int BUTTON = 4;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(192,168,2,115);
IPAddress ip(192,168,2,145);
EthernetClient client;
  pinMode(LED,OUTPUT);
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    Ethernet.begin(mac, ip);
  Serial.println("connecting...");
  httpRequest();
void httpRequest() {
    client.connect(server, 80);
    client.println("POST /checkPass.php?somePass="+mxx);
    client.println("Host: 192.168.2.115");
    client.println("Name: <input type=\"submit\">");
    client.println();
    char c = client.read();
    client.available();
    Serial.print(c);
    if(c=='/'){                                                    //check data from server and led on
      Serial.println("ok");
      digitalWrite(LED,HIGH);
    if (!client.connected()) {
    Serial.println("disconnecting.");
    delay(3000);                                      // delay led around 3 sec before sent data to server again
    digitalWrite(LED,LOW);
    client.stop();
now i use this code with NDEF P2P Receive code
i want
✓ [arduino waiting for ndef messgae from androidphone]
✓ [touch androidphone to beam ndef message to arduino]
✗ [sent ndef message from arduino to server]
✗ [get some data back from server]
✗ [if some data is correct led on]
✓ [arduino waiting for ndef messgae again and looping like this]
this is NDEF P2P Receive code + web client and it’s have a problem
#include "SPI.h"
#include "PN532_SPI.h"
#include "snep.h"
#include "NdefMessage.h"
#include "Wire.h"
#include <SPI.h>
String mxx ;
int LED = 8;
int BUTTON = 4;
PN532_SPI pn532spi(SPI, 9);
SNEP nfc(pn532spi);
uint8_t ndefBuf[128];
    Serial.println("NFC Peer to Peer Example - Receive Message");
    Serial.println("Waiting for message from a peer");
    int msgSize = nfc.read(ndefBuf, sizeof(ndefBuf));
    if (msgSize > 0) {
        NdefMessage msg  = NdefMessage(ndefBuf, msgSize);
        NdefRecord record = msg.getRecord(0);
        int payloadLength = record.getPayloadLength();
        byte payload[payloadLength];
        record.getPayload(payload);
        int startChar = 0;
        if (record.getTnf() == TNF_WELL_KNOWN && record.getType() == "T") { // text message
          // skip the language code
          startChar = payload[0] + 1;
        } else if (record.getTnf() == TNF_WELL_KNOWN && record.getType() == "U") { // URI
          startChar = 1;
        String payloadAsString = "";
        for (int c = startChar; c < payloadLength; c++) {
          payloadAsString += (char)payload[c];
        Serial.print(payloadAsString);
        mxx=payloadAsString;
        httpRequest();                                                      // call webclient function
        Serial.println("\nSuccess");
        Serial.println("Failed");
    delay(3000);
    Serial.println(mxx);
    client.println();
    client.available();
    Serial.print(c);
    if(c=='/'){
     //delay(1000);
     client.stop();
it’s don’t sent data to server
i don’t know why
thanks
jame35: i use PN532 + ethernet shield with arduino UNO
it's don't have a problem
Yes, it does. You are not reading the response from the server, and you may not be closing the connection before attempting a new connection.
Try these examples. The first on this page is a GET and the second is a POST. http://playground.arduino.cc/Code/WebClient
Then you need to post a link to the PN532 hardware you have, and how you have it connected to the Uno.
i use POST request and it fail again
code
#include "SPI.h"
#include "snep.h"
#include "Wire.h"
#include <SPI.h>
byte mac[] = {
//Change to your server domain
char serverName[] = "192.168.2.115";
// change to your server's port
int serverPort = 80;
// change to the page on that server
char pageName[] = "/checkPass.php?somePass=fa42be0504a2e78dd09e9f72f306c811f351f516809db065c70f7d7748c6aba1";
int totalCount = 0;
// insure params is big enough to hold your variables
char params[32];
// set this to the number of milliseconds delay
// this is 30 seconds
#define delayMillis 5000UL
unsigned long thisMillis = 0;
unsigned long lastMillis = 0;
SNEP nfc(pn532spi);
      // disable SD SPI
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Serial.print(F("Starting ethernet..."));
  if(!Ethernet.begin(mac)) Serial.println(F("failed"));
  else Serial.println(Ethernet.localIP());
  delay(2000);
  Serial.println(F("Ready"));
    if (msgSize > 0) {
        //msg.print();
        int startChar = 0;
          startChar = 1;
        functiona();
    delay(3000);
void functiona(){
    thisMillis = millis();
  if(thisMillis - lastMillis > delayMillis)
    lastMillis = thisMillis;
    // params must be url encoded.
    sprintf(params,"temp1=%i",totalCount);
    if(!postPage(serverName,serverPort,pageName,params)) Serial.print(F("Fail "));
    else Serial.print(F("Pass "));
    totalCount++;
    Serial.println(totalCount,DEC);
byte postPage(char* domainBuffer,int thisPort,char* page,char* thisData)
  int inChar;
  char outBuf[64];
  Serial.print(F("connecting..."));
  if(client.connect(domainBuffer,thisPort) == 1)
    Serial.println(F("connected"));
    // send the header
    sprintf(outBuf,"POST %s ",page);
    client.println(outBuf);
    sprintf(outBuf,"Host: %s",domainBuffer);
    client.println(F("Connection: close\r\nContent-Type: application/x-www-form-urlencoded"));
    sprintf(outBuf,"Content-Length: %u\r\n",strlen(thisData));
    // send the body (variables)
    client.print(thisData);
    return 0;
  int connectLoop = 0;
  while(client.connected())
    while(client.available())
      inChar = client.read();
    if(inChar=='/'){
      digitalWrite(8,HIGH);
      Serial.write(inChar);
      connectLoop = 0;
    delay(1);
    connectLoop++;
    if(connectLoop > 10000)
      Serial.println(F("Timeout"));
      client.stop();
  delay(3000);
  digitalWrite(8,LOW);
  Serial.println(F("disconnecting."));
  client.stop();
  return 1;
Serial monitor respond
Starting ethernet...192.168.2.145
Ready
connecting...failed
Fail 1
Success
Success
connecting...failed
Fail 2
Success
    connecting...failed
Fail 3
Success
connecting...failed
Fail 4
Success
    connecting...failed
Fail 5
Success
You didn't post how you have the PN532 connected.
But despite that, you are expecting the DNS server to resolve a localnet IP. That normally causes a DNS fail.
// change this
// to this
IPAddress serverName(192,168,2,115);
// and change this
// to this
byte postPage(IPAddress domainBuffer,int thisPort,char* page,char* thisData)
my PN532 NDEF P2P Recieve Code
#include "SPI.h"
#include "snep.h"
#include "Wire.h"
SNEP nfc(pn532spi);
    if (msgSize > 0) {
        //msg.print();
        int startChar = 0;
          startChar = 1;
    delay(3000);
Ethernet shield on Arduino UNO
LED on Pin8
PN532 Pin::
SCK >> 13
MISO >> 12
MOSI >> 11
SS >> 9 (because of this problem >> http://forum.arduino.cc/index.php?topic=320313.0)
VCC >> 5V
GND >> GND
OK, did you change the code to the IPAddress instead of a character array?
SurferTim: OK, did you change the code to the IPAddress instead of a character array?
yes, i do and it fail like Serial monitor respond in #2
Have you tried the ethernet code without adding the PN532 library but leaving the PN532 connected? Add just these two lines to the setup of the ethernet code.
    // disable SD SPI
  pinMode(4,OUTPUT);
// add this to disable PN532 SPI
  pinMode(9,OUTPUT);
  digitalWrite(9,HIGH);
still the same
Have you tried connecting to the server (192.168.2.115) with a PC on that localnet? From the server itself doesn't count.
The only other test I can suggest is disconnect all the PN532 SPI data lines (D11 to D13) from the Arduino and try the ethernet code. Then connect each line one at a time and try it again. One or more of those pins should cause that fail. Which pin is it? If I had to guess, it will be D12.
edit: Maybe a link to the PN532 breakout board you are using will help.
