i’ve got a Problem to connect an Arduino UNO with a Ethernet Shield W5100 to more than 4 Servers over the Etherner Library.
When i try to connect to 4 Servers it works… but when i try more than 4 it stucks and can’t get connected.
I read the distance of a sensor and send it to 6 Server (5 for Animation, 1 for Light)
I’ve changed the order of connections in init2() and everytime the last two don’t connect.
Then i only try 5, same failure - last one don’t connect.
The i try only 4 connections and it works.
Here is my Code i don’t know where the fault is.
I’ve tested the init2() and initConnectionMethod() but same fault.
Can someone please help me to find the mistake?
#include <Ethernet.h>
#include <SPI.h>
// ultrasonic pin
int echoPin = 7; // Input Pin, digital pin 7
int trigPin= 8; // Output Pin, digital pin 8
//networkconfig
//Arduino IP 192.168.178.10 - .19
byte mac[] = { 0xA1, 0xA1, 0xA1, 0xA1, 0xA1, 0xA1 };
byte ip[] = { 192, 168, 178, 10 };
byte subnetmask[] = { 255, 255, 255, 0};
//Light Animation Server IP 192.168.0.1
byte server[] = { 192, 168, 178, 1 };
int serverPort = 5555;
//Rasperry Animation IP .20 - .24
int raspPort = 6667;
byte raspA[] = { 192, 168, 178, 20 };
byte raspB[] = { 192, 168, 178, 21 };
byte raspC[] = { 192, 168, 178, 22 };
byte raspD[] = { 192, 168, 178, 23 };
byte raspE[] = { 192, 168, 178, 24 };
byte current = -1;
byte zero=0;
byte one=1;
byte two=2;
byte three=3;
byte id=16;
EthernetClient client;
EthernetClient clientRaspA;
EthernetClient clientRaspB;
EthernetClient clientRaspC;
EthernetClient clientRaspD;
EthernetClient clientRaspE;
Serial.begin (9600);
Ethernet.begin(mac, ip);
//stay in loop while not connected
init2();
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
if(client.connected() && clientRaspA.connected() && clientRaspC.connected() && clientRaspD.connected() && clientRaspE.connected())
Serial.println("connected");
client.write(id);
sendDataToRasps(id);
// No connection
while(client.connected() && clientRaspA.connected() && clientRaspC.connected() && clientRaspD.connected() && clientRaspE.connected())
getSensorData();
void init2()
int test=0;
while((test= client.connect(server, serverPort))!=1)
test=0;
Serial.println("connected to dmx");
while((test= clientRaspA.connect(raspA, raspPort))!=1)
test=0;
Serial.println("connected to Rasp A");
while((test=clientRaspB.connect(raspB, raspPort))!=1)
test=0;
Serial.println("connected to Rasp B");
while((test= clientRaspC.connect(raspC, raspPort))!=1)
test=0;
Serial.println("connected to Rasp C");
while((test= clientRaspD.connect(raspD, raspPort))!=1)
test=0;
Serial.println("connected to Rasp D");
while((test= clientRaspE.connect(raspE, raspPort))!=1)
test=0;
Serial.println("connected to Rasp E");
void initConnection()
Serial.println("init connect");
do
int i=client.connect(server, serverPort);
Serial.println(i);
delay(30);
}while(!client.connected());
do
clientRaspA.connect(raspA, raspPort);
delay(30);
}while(!clientRaspA.connected());
Serial.println("connected to rasp A");
do
clientRaspC.connect(raspC, raspPort);
delay(30);
}while(!clientRaspC.connected());
Serial.println("connected to rasp C");
do
clientRaspD.connect(raspD, raspPort);
delay(30);
}while(!clientRaspD.connected());
Serial.println("connected to rasp D");
do
clientRaspE.connect(raspE, raspPort);
delay(30);
}while(!clientRaspE.connected());
Serial.println("connected to rasp E");
void getSensorData()
long duration;
long distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2); //
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1; // distance in cm
if(distance <0 ) //
sendDataToRasps(zero);
else if (distance >=0 && distance < 20) // >
sendDataToRasps(three);
client.write(one);
else if(distance >=20 && distance < 60)
sendDataToRasps(two);
client.write(zero);
else if (distance >= 60 && distance < 100)
sendDataToRasps(one);
client.write(zero);
else //if (distance >=100)
client.write(zero);
delay(30);
void sendDataToRasps(byte value)
clientRaspA.write(value);
//clientRaspB.write(value);
clientRaspC.write(value);
clientRaspD.write(value);
clientRaspE.write(value);
Thank you for your help.
