Ethernet Shield Connection problem on Ubuntu
Hi Basically i am Stuck on this first step of connecting ethernet shield on ubuntu.
i have arduino UNO attached with the shield i have made manual ip settings on my pc and arduino.
Searched a lot for this problem Still not able to connect these to pls help.
PC ip adress:
192.168.1.17
mask: 255.255.255.0
gateway: 192.168.1.1
arduino ip:
192.168.1.18
255.255.255.0
Demo code Source: instructables
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 18 }; // fixed IP addr in LAN
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup () {
pinMode(6, OUTPUT); //pin selected to control LED
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
Serial.println("server LED test 1.0 ---- FILENAME = LED2.ino "); // so I can keep track
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Home Automation</TITLE>");
client.println("</HEAD>");
client.println("<BODY bgcolor='aqua'>");
client.println("<H1>Home Automation</H1>");
client.println("<hr />");
client.println("
client.println("<a href=\"/?lighton\"\">Turn On Light</a>");
client.println("<a href=\"/?lightoff\"\">Turn Off Light</a>
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
// control arduino pin
if (readString.indexOf("?lighton") >0)
//checks for on
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("LED On");
else {
if(readString.indexOf("?lightoff") >0)//checks for off
digitalWrite(6, LOW); // set pin 6 low
Serial.println("LED Off");
readString=""; //clearing string for next read
Got it working With arduino ENC28J60 Library..
which can be D/w from:
