I’m trying to achieve two things and am having difficulty pulling it off. I have an Uno with an Ethernet shield which is connected to an RF remote that controls lights. I am able to instantly turn on and off my lights using any device connected to my wi-fi. What I’m looking to do is to also have Twitter support. So if I tweet anything that starts with an “h”, I want it to turn my lights on. I have some code that is able to achieve this, except there’s a few problems that I’m struggling with.
For some reason, when I run my program, both the wifi and twitter functions stop working. If I comment out one out of the two, it works. To make the checkTwitter function work, I have to comment out the entire checkWifi function, not only the one in the main loop, therefore I think the problem is coming from my checkWifi function. I thought it might be the client variable, so I made two separate ones, but no luck. I believe it may have something to do with the server port, but I’m not sure how to fix it. Any help will be appreciated.
#include <SPI.h>
#include <Ethernet.h>
#include <TextFinder.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
192, 168, 1, 127 }; // ip in lan
byte gateway[] = {
192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
EthernetClient client;
EthernetClient client2;
String readString;
String TwitterName ="josemunoz552"; //change this to your own twittername, or follow me ;-)
char tweet[140];
byte charsize2;
char serverName[] = "api.twitter.com";
String SearchDate="<description>josemunoz552: ";
char code[] = "h";
char Twitdate[140];
long TwitterCheckInterval=60000;
unsigned long lastTwitterCheck;
void setup(){
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(7, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//the pin for the servo co
//enable serial data print
void loop(){
// Create a client connection
checkWifi();
if (millis()-lastTwitterCheck > TwitterCheckInterval){
checkTwitter();
Serial.println("checking Twitter now");
lastTwitterCheck += TwitterCheckInterval;
void checkWifi(){
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<style> body { background-color:#d0e4fe; }</style>");
client.println("<TITLE>Moe's Home Automation</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Moe's Home Automation</H1>");
client.println("<hr />");
client.println("
client.println("<a href=\"/?lighton1\"\"><img src='http://files6.fliiby.com/images/_original/ud5qurg7qw.png'></a>");
client.println("<a href=\"/?lightoff1\"\"><img src='http://files6.fliiby.com/images/_original/ud5qurg7qw.png'></a>
client.println("<a href=\"/?lighton2\"\"><img src='http://files6.fliiby.com/images/_original/ud5qurg7qw.png'></a>");
client.println("<a href=\"/?lightoff2\"\"><img src='http://files6.fliiby.com/images/_original/ud5qurg7qw.png'></a>
client.println("<a href=\"/?lighton3\"\"><img src='http://files6.fliiby.com/images/_original/ud5qurg7qw.png'></a>");
client.println("<a href=\"/?lightoff3\"\"><img src='http://files6.fliiby.com/images/_original/ud5qurg7qw.png'></a>
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("?lighton1") >0)//checks for on
digitalWrite(2, HIGH); // set pin 2 high
digitalWrite(8, HIGH);
delay(250);
digitalWrite(2, LOW); // set pin 2 high
digitalWrite(8, LOW);
Serial.println("Led 1 On");
client.println("<a href=\"/?lightAon\"\"><img src='http://files6.fliiby.com/images/_original/ud5qurg7qw.png'></a>");
else{
if(readString.indexOf("?lightoff1") >0)//checks for off
digitalWrite(4, HIGH); // set pin 2 high
delay(250);
digitalWrite(4, LOW); // set pin 2 high
digitalWrite(8, LOW); // set pin 4 low
Serial.println("Led 1 Off");
client.println("<link rel='apple-touch-icon' href='http://files6.fliiby.com/images/_original/ud5qurg7qw.png' />");
//clearing string for next read
if(readString.indexOf("?lighton2") >0)//checks for on
digitalWrite(3, HIGH); // set pin 2 high
delay(250);
digitalWrite(3, LOW); // set pin 2 high
Serial.println("Led 2 On");
else{
if(readString.indexOf("?lightoff2") >0)//checks for off
digitalWrite(5, HIGH); // set pin 2 high
delay(250);
digitalWrite(5, LOW); // set pin 2 high
Serial.println("Led 2 Off");
if(readString.indexOf("?lighton3") >0)//checks for on
digitalWrite(6, HIGH); // set pin 2 high
delay(250);
digitalWrite(6, LOW); // set pin 2 high
digitalWrite(8, LOW); // set pin 4 low // set pin 2 high
Serial.println("Led 3 On");
else{
if(readString.indexOf("?lightoff3") >0)//checks for off
digitalWrite(7, HIGH); // set pin 2 high
digitalWrite(9, HIGH); // YO
delay(250);
digitalWrite(7, LOW); // set pin 2 high
digitalWrite(9, LOW); // YO
digitalWrite(8, LOW); // set pin 4 low; // set pin 4 low
Serial.println("Led 3 Off");
readString="";
void checkTwitter(){
if (client2.connect(serverName, 80)) {
TextFinder finder( client2,2 );
// Serial.println("HTTP Request Initialized");
// make HTTP GET request to twitter:
client2.print("GET /1/statuses/user_timeline.rss?screen_name=");
client2.print(TwitterName);
client2.println("&count=1 HTTP/1.1");
client2.println("HOST: api.twitter.com");
client2.println();
while (client2.connected()) {
if (client2.available()) {
Serial.println("Searching for new tweet");
charsize2 = SearchDate.length();
char StartHere[charsize2];
char EndHere[] = "</title>";
char EndDate[]= "</pubDate>";
SearchDate.toCharArray(StartHere,charsize2);
if((finder.find("<item>")&&(finder.getString(StartHere,EndHere,Twitdate,140)!=0)))
Serial.println(Twitdate);
Serial.println(Twitdate[1]);
if(Twitdate[1]==code[0]){
else{
delay(1);
client2.stop();
