hello
can i control Ethernet Shield with another computer that not connect to the specific router that the ethernet shield is connected to?
thanks
If you set up port forwarding correctly you can communicate with the Arduino from any other node on the Internet.
You would usually set up port forwarding on the router that connects your LAN to the Internet.
thanks for the answare ![]()
can you please give me an example for what you mean?
There are many examples here: http://portforward.com
If the computer is not uo your lan, you might use one of the dynamic IP services (like no-ip.com) in addition to the port forwarding on the lan router.
