Ethernet Shield ENC28J60
Hi guys :slight_smile: this is the first time I write in the forum even though it is already for a while that I work with Arduino Mega 2560 :slight_smile: I feel phenomenal ... a friend wanted to reward myself and I bought an Ethernet Shield :frowning: aime is not the original but is based on the chip ENC28J60, I checked on ebay and even those who sell it provides a different library from the original to this link: http://www.r3cube.com/Drivers-software/etherShield.zip
I tried to connect the Arduino Ethernet Shield to, and placed the little program that was present in the test library, but if I ping the ethernet I give the software to shield ... I do not see the device ... I know someone help?
I wanted to point out that I am working with the power to the USB port ... with the cable programming ...
example is the program that the library is as follows:
#include "etherShield.h"
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = {192,168,1,15};
static char baseurl[]="http://192.168.1.15/";
static uint16_t mywwwport =80; // listen port for tcp/www (max range 1-254)
// or on a different port:
//static char baseurl[]="http://10.0.0.24:88/";
//static uint16_t mywwwport =88; // listen port for tcp/www (max range 1-254)
#define BUFFER_SIZE 500
static uint8_t buf[BUFFER_SIZE+1];
#define STR_BUFFER_SIZE 22
static char strbuf[STR_BUFFER_SIZE+1];
EtherShield es=EtherShield();
// prepare the webpage by writing the data to the tcp send buffer
uint16_t print_webpage(uint8_t *buf);
int8_t analyse_cmd(char *str);
void setup(){
   /*initialize enc28j60*/
	 es.ES_enc28j60Init(mymac);
   es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
   delay(10);
	/* Magjack leds configuration, see enc28j60 datasheet, page 11 */
	// LEDA=greed LEDB=yellow
	// 0x880 is PHLCON LEDB=on, LEDA=on
	// enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00);
	es.ES_enc28j60PhyWrite(PHLCON,0x880);
	// 0x990 is PHLCON LEDB=off, LEDA=off
	// enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00);
	es.ES_enc28j60PhyWrite(PHLCON,0x990);
  // 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
  // enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10);
  es.ES_enc28j60PhyWrite(PHLCON,0x476);
	delay(100);
  //init the ethernet/ip layer:
  es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
void loop(){
  uint16_t plen, dat_p;
  int8_t cmd;
  plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
	/*plen will ne unequal to zero if there is a valid packet (without crc error) */
  if(plen!=0){
    // arp is broadcast if unknown but a host may also verify the mac address by sending it to a unicast address.
    if(es.ES_eth_type_is_arp_and_my_ip(buf,plen)){
      es.ES_make_arp_answer_from_request(buf);
      return;
    // check if ip packets are for us:
    if(es.ES_eth_type_is_ip_and_my_ip(buf,plen)==0){
      return;
    if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
      es.ES_make_echo_reply_from_request(buf,plen);
      return;
    // tcp port www start, compare only the lower byte
    if (buf[IP_PROTO_P]==IP_PROTO_TCP_V&&buf[TCP_DST_PORT_H_P]==0&&buf[TCP_DST_PORT_L_P]==mywwwport){
      if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V){
         es.ES_make_tcp_synack_from_syn(buf); // make_tcp_synack_from_syn does already send the syn,ack
         return;
      if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V){
        es.ES_init_len_info(buf); // init some data structures
        dat_p=es.ES_get_tcp_data_pointer();
        if (dat_p==0){ // we can possibly have no data, just ack:
          if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V){
            es.ES_make_tcp_ack_from_any(buf);
          return;
        if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
          	// head, post and other methods for possible status codes see:
            // http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
            plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>200 OK</h1>"));
            goto SENDTCP;
 	if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
                plen=print_webpage(buf);
            goto SENDTCP;
        cmd=analyse_cmd((char *)&(buf[dat_p+5]));
        if (cmd==1){
SENDTCP:  es.ES_make_tcp_ack_from_any(buf); // send ack for http get
           es.ES_make_tcp_ack_with_data(buf,plen); // send data
// The returned value is stored in the global var strbuf
uint8_t find_key_val(char *str,char *key)
        uint8_t found=0;
        uint8_t i=0;
        char *kp;
        kp=key;
        while(*str &&  *str!=' ' && found==0){
                if (*str == *kp){
                        kp++;
                        if (*kp == '\0'){
                                str++;
                                kp=key;
                                if (*str == '='){
                                        found=1;
                }else{
                        kp=key;
                str++;
        if (found==1){
                // copy the value to a buffer and terminate it with '\0'
                while(*str &&  *str!=' ' && *str!='&' && i<STR_BUFFER_SIZE){
                        strbuf[i]=*str;
                        i++;
                        str++;
                strbuf[i]='\0';
        return(found);
        int8_t r=-1;
        if (find_key_val(str,"cmd")){
                if (*strbuf < 0x3a && *strbuf > 0x2f){
                        // is a ASCII number, return it
                        r=(*strbuf-0x30);
        return r;
        uint16_t plen;
     		plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"));
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><p><h1>Welcome to Arduino Ethernet Shield V1.0  </h1></p> "));
       	plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<hr>
 <h2><font color=\"blue\">-- Put your ARDUINO online -- "));
 Control digital outputs "));
 Read digital analog inputs HERE "));
</font></h2> ") );
        plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</center><hr>  V1.0 <a href=\"http://www.nuelectronics.com\">www.nuelectronics.com<a>"));
        return(plen);
I put the code you've posted on my arduino board and connected it to an ENC28J60 breakout board. It works.
You must make sure that the pins defined in enc28j60.c are correct.
#define ENC28J60_CONTROL_CS  10
#define SPI_MOSI             11
#define SPI_MISO             12
#define SPI_SCK              13
