Ethernet shield gives unknown command at startup connection
Hello,
I got an Arduino Mega + Ethernet shield (V2).
On it I run the DHCP Chat Server with of course modifications.
When I connect to the Arduino setup with TeraTerm in Telnet mode, then I receive a unknown command at the arduino side (sending all data from the Ethernet shield by a serial connection to the screen).
This happens also when the setup is in idle mode (waiting for user input by telnet) between 5 to 10 min.
I have no idea where to look for this issue. Is this some establishment data?
Anyone with the same issue or any idea where to look for?
Thanks in advance!
Do you plan to share what you get on the arduino side or do we need to guess?
Have you tried with a simpler program on the arduino to log in the console what you get upon establishing your telnet connection?
You are connecting to a Telnet server. Have you looked at the Telnet protocol specification to see what that message means?
J-M-L:
Point taken, I checked with the example project of the ethernet shield (DhcpChatServer) and then I receive
teraterm settings: TCP/IP, Service:Telnet, TCP port#:23, Protocol: IPv4
The data that I receive at the Arduino side after making the connection:
"⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮K" and 2 rows more of this kind of data.
johnwasser:
I did not, mostly because I have absolutely no clue what this data is?
Could you help me with the Telnet protocol specifications?
i have tried it with windows CMD in Telnet setting and there the unknown commands are not there so @johnwasser, I think you are correct. I assume that it is in the Telnet settings by TeraTerm.
