ethernet shield + gsm/gprs sim900 modules
Hello! I use sim900 modules and ethernet shield to send sms to my server. I use code like:
IPAddress server(111,111,111,111);
int send_sms_status = 2;
EthernetClient client;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
   pinMode(SEND_LED, OUTPUT);
   Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  if (notConnected==false)
 Serial.println("\nCOMPLETE!\n");
      // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
      Serial.print("My IP address: ");
      for (byte thisByte = 0; thisByte < 4; thisByte++) {
        Serial.print(Ethernet.localIP()[thisByte], DEC);
        Serial.print(".");
void loop () {
  char c;
  Serial.println("Wait for sms...");
  Serial.println(GetSms);
  if (GetSms==true)
  blink_diod (GET_SMS_LED, 400);
  if (sms.available())
    GetSms = true;
    // Get remote number
    sms.remoteNumber(senderNumber, 20);
    // An example of message disposal
    // Any messages starting with # should be discarded
    if(sms.peek()=='#')
      Serial.println("Discarded SMS");
      sms.flush();
  //  analogWrite(LED, 250);
    int o = 0;
    // Read message bytes and print them
    while(c=sms.read())
     // Serial.print(c);
      sms_text [o] = c;
      o++;
    Serial.println("\nEND OF MESSAGE");
    // Delete message from modem memory
    sms.flush();
    Serial.println("MESSAGE DELETED");
    Serial.println("Message received from:");
    Serial.println(senderNumber);
    Serial.println("With text:");
    Serial.println(sms_text);
   SmsText = sms_text;
   TelNum = senderNumber;
 //connectToServer("dfdf", "555");
 Serial.println("connecting...");
send_sms_status = 1;
  if (client.connect(server, 80))
    Serial.println("connected");
    PrevMillForSend = millis();
  start_send_serv = true;
  String temp = "data=5";
           Serial.println("Sending to Server: ");
client.println("POST /get_sms.php HTTP/1.1");
Serial.print("POST /get_sms.php HTTP/1.1");
client.println("Host: mysite.com");
//client.print("Content-Length: ");
//client.println(temp.length());
client.println();
client.print(temp);
client.println();
    Serial.println("connection failed");
When i use only this code all is okey: i get message:“SMS Messages Sender”, “GSM initialized”… and get “My IP address:” and every second get “Wait for sms…” but on my server side i have
empty POST header.
I understand that it’s happened because the lines
are commented
BUT if i uncomment i have only “SMS Messages Sender” and nothing more…
Maybe someone knows what could be the problem? I would be very grateful for the help!!!
